Victor Jr. users inside!!!!!
Old Jan 29, 2010 | 05:48 PM
ninetres's Avatar
Default Victor Jr. users inside!!!!!
Quick question. Has anyone had issues running them with the stock style o-ring gaskets with boost? What about 20+ psi boost? I know I have seen a lot of the 7 and 8 second guys running them.
One of my local shops recently had one come apart at 12 psi. They ended up filling and re-surfacing the o-ring grooves and then used traditional style gaskets.
I have never heard of this issue. Anyone else? My intake is being port matched right now and the porter was asking me if I wanted to have mine filled in.
Thanks.
Old Jan 29, 2010 | 06:01 PM
Tiago's Avatar
I haven't ran 20+ lbs but at 15 its all good....
Old Jan 29, 2010 | 06:46 PM
OUTLAWZ RACING's Avatar
18 psi no issue here.
Old Jan 29, 2010 | 06:48 PM
Dean95z28's Avatar
I think it is hit or mis with those intakes... I know there was a problem with the aluminum breaking at the edges of the vic jr's where the o rings go. But I think it was due to over torqueing the bolts. I am using one of them but I am only running 11psi.
Old Jan 29, 2010 | 09:02 PM
Mr_president's Avatar
We can use my pressure washer to find out. It will do about 20 PSI no problem ...
Old Jan 29, 2010 | 09:17 PM
jashell1562's Avatar
21 psi with 0 issues....well I have belt slip but thats unrelated.
Old Jan 29, 2010 | 09:56 PM
ninetres's Avatar
Mr president????? Welcome back. Change your sig to your v6 camaro and ricer beemer
Old Jan 30, 2010 | 06:47 AM
Navy David SS's Avatar
No problems with mine - 23lbs. I did switch to the Super Victor. The Super looks like it will be a much better intake for boost. I have no complaints about the Jr, it did the job.
David
Old Jan 30, 2010 | 08:48 AM
98transguy's Avatar
also 21psi here no problems
Old Jan 30, 2010 | 09:34 AM
HUNTER02SS's Avatar
On my old TT setup I had the Vic Jr. On the passenger side the back porrt where the rubber o-ring sit was milled out to close to the edge and ended up breaking off. We had to re-weld it and had no problems out of it after that. I have switched to super vic as well. Alot thicker on the deck surface.
Old Jan 30, 2010 | 10:32 AM
ninetres's Avatar
Isn't the super vic taller?
Old Jan 30, 2010 | 10:37 AM
TurboAv's Avatar
Yes it is.
Old Jan 30, 2010 | 11:09 AM
SKINNY69's Avatar
Since we're on the topic of Victor series manis, does anyone run one of these box style elbows? Looks like it would clear the hood and cowl but I'd like to know how they perform on a boosted application.
Old Jan 30, 2010 | 12:03 PM
chance575's Avatar
the edelbrock elbows do not flow at all, check out intakeelbows(you know the dot part) for a nice sheet metal one
Old Jan 30, 2010 | 01:09 PM
forcd ind's Avatar
my intake broke down by the valley, took it off and welded it up, cyls 1 and 3 right at the bottom by the o ring
one thing i have experienced was best to use the stock GM o rings, i had some NAPA orange ones, they were a lot cheaper, but kind of came apart, so i went back to the GM ones-i wonder if you can use the trad. ones w/o filling the groove-i know they have them in a couple diff thicknesses
Old Jan 30, 2010 | 03:50 PM
TwnTrboCE's Avatar
I've ran a Jr for a couple years with the stock O-rings out of my LS1 intake. Mine has been well over 30psi and the gaskets are still in place.
Old Jan 30, 2010 | 06:30 PM
Inspector12's Avatar
TT-TECH Veteran
Ran 23lbs on mine no issues.
Old Jan 30, 2010 | 07:34 PM
reamo04's Avatar
so, whats the proper torque rating for these?11 ft/lbs right?
Those that have broken them, what did you have yours torqued to?
Those that have had them fine for higher boost, what did you have yours torqued to?
