EPP FI cam + 5.3
LS1Tech Sponsor
You have to be careful with the cams on the 4.8s and 5.3s unless you want to run an extremely loose converter. We have two 5.3l turbo grinds for street cars that work well in keeping the low rpm power. One sounds like stock and makes 30whp more then the ls6 at 8-10psi and the second will make as much as 45-50hp over the ls6 cam at 10psi. The bigger one has some chop too it though, but works well up to 900fwhp with the 5.3l and a long runner intake.
If you try to stab a cam in a turbo 5.3l in the 23x duration range it will be a turd when it comes to lighting the turbo up.
Mark K runs the smaller one in his Monte Carlo SS with a turbo 5.3l. He has run 11.0@127 with his on pump gas and its a pretty heavy FWD car to boot.
A friend and I tried this before, and either cam was ground with a few degrees of retard, or it really was way too much for the 5.3. We lost what felt like a-lot of power with the swap vs a GT2-3 cam, put the GT2-3 back in and the power was back.
I just bought the epp cam from brutespeed, its the same grind from comp. We will see what it makes. I think it will be just fine, 5.3 with 6.0 heads e85 76mm turbo. If it does not work I will change it up. I plan on going 6.0 next year so I think with more cubes that cam will work great.
LS1Tech Sponsor
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
