boost issue ,, iit does not hold
Old Feb 5, 2010 | 04:05 AM
Kwt_DragerZ's Avatar
Exclamation boost issue ,, iit does not hold
Hi guys ,, i have 2002 camaro it has 408 c.i.d and KYTP s91 turbo kit.
i finished every thing but when we put it on the dyno to tune it it opens 15 psi ,,, so when we put the boost controller 20 psi or 22 or 26 or any number it just go down to between 15 and 15.5 .
so is the problem is the boost controller ( Exile ) ?? or it is from the wastgate ??
please help my gust to finish my project ,, Thanks
Old Feb 5, 2010 | 05:58 AM
OUTLAWZ RACING's Avatar
What boost controller? Some u have to set the values in order to get the proper boost. And what gate spring iin there?
Old Feb 5, 2010 | 06:27 AM
i'm using Exile Boost controller and JGS 60mm wastegate with High (0.162" wire) Spring ,, but i don't know what is happing the car is spooling at the dyno with 20 psi then it drops to 15 or 14 psi . Also , when i setup the controller with 20 or higher boost it does not change any thing so what is the poblem ???
Old Feb 5, 2010 | 06:40 AM
98Z28CobraKiller's Avatar
Restricted User
Try getting a small air regulator and putting some shop air on the back of the gate. If it still does it, then your problem is something else.
