D1 - Keying Crank?
How many people have keyed their crank?
And what is the best way to go about this?
Thanks guys
Eliminate Damper Shift with the ATI Crank Pin Drill Fixture Kit for LS1
http://www.atiperformanceproducts.co...s/pr/30402.htm
I haven't done it yet... I was trying to get another pulley that would mate to my ATI Superdamper (which already has a keyway). I guess I will go ahead and get a keyway cut in mine (or one from the salvage yard to replace it with).
You are in Raleigh? I am in Jacksonville NC. I plan on getting the car tuned at CAM in Durham, I would love to check out your ride one of these days. Your car is one of the reasons I went FI.
Would you guys agree that Keying is not an option to skip?
My first ATI car I never pinned the crank and it never came loose after a lot of beating and 10,000 miles at 6psi so I dont think at level its important. I am going to be pullying mine up some so I did it to be safe..
If you have a superdamper, ATI (the damper company) has a different fixture that drills 2 holes in the side (as opposed to the front like the ATI blower company tool) and then you can use the keyway in your damper. Thats the one blackls1/ta posted a link to. Someone on corvetteforum was renting one out for a few bucks a while back.
Its a better setup then drilling the crank from the front since its going to be a pain to line the pin up when putting my damper on but its better then nothing
