BMR k-frame issues....
That’s why the rear holes in the stock K-member is so big and the bolt
has a big washer.
Look at the washer bite marks on the stock K-member, all the ones I’ve
seen are far from center.
the bmr k member is just as difficult to install, except that you have to bend the brake lines a bit.
This is correct about the rear most holes in the K-member.
From the factory these holes run large to help accommodate variations in the manufacturing of the vehicle.
Thanks again, Lee
I now feel like a dumb-***, but better-off for finally catching this problem.
Just something to be aware of.....
Thanks again, Lee
At least you decided to pursue the issue instead of just writing it off as poor workmanship on our part...I appreciate it
