pt76gts numbers?
Old Feb 10, 2010 | 11:22 PM
Slow5.0.'s Avatar
Default pt76gts numbers?
Havnt been able to find a great amount of builds with this turbo. If you have some dyno /track mph numbers (psi?) Im curious to see how it reacts on diff size motors.
Old Feb 10, 2010 | 11:29 PM
black98ws6ta's Avatar
150 mph at 3700 lbs on a 281 cu in motor. 750 rwhp on a 402 ls motor through a 6 speed.
Old Feb 10, 2010 | 11:43 PM
355TurboLT1's Avatar
Man a 76GTS on a 402!? THats a small turbo for that motor.
Old Feb 10, 2010 | 11:45 PM
Yeah, its alittle mis matched but it works.
Old Feb 11, 2010 | 12:52 AM
chase3's Avatar
How many pounds of boost to get those numbers?
Old Feb 11, 2010 | 09:52 AM
OUTLAWZ RACING's Avatar
76 gts rearmount 4xx numbers in the sig. I also trap 142 in the quater.
Old Feb 11, 2010 | 10:02 AM
12 psi. I would recommend doing a larger turbo, but this guy was set on trying it.
Old Feb 11, 2010 | 10:26 AM
$ho_tyme's Avatar
You have a mp t70 rite? Why not just add another?
Old Feb 12, 2010 | 02:34 AM
Slow5.0.'s Avatar
150 is flyin! This turbo seems to work reeeally well with smaller v8's. I bet the 5.3 could make more power then the 6.0 w/ this turbo.
Old Feb 12, 2010 | 09:56 AM
lq4pwns's Avatar
what are you getting at here???
Old Feb 12, 2010 | 09:59 AM
That is true with almost all turbo's, but there are some exceptions.
Old Feb 12, 2010 | 02:09 PM
NicD's Avatar
7 Second Club
Here is my last dyno chart with the 6 speed with a 76gts.
Old Feb 12, 2010 | 02:15 PM
Slow5.0.'s Avatar
NICE
haha
Old Feb 12, 2010 | 06:32 PM
engineermike's Avatar
3750 lb, 388 cid LTx with a TH350 and loose converter:
9.9 (1.7 60' leaving soft) at 146 mph and 700 rwhp, all at 17 psi. There was still more in it, as the turbo was capable of 20+ psi.
Most say the turbo is too small for 388 cid, but I had good luck with it.
Also... we ran a similar combo on an engine dyno. It was 377 cid with a 230/230 cam and air/air and made 930 hp and 1070 ft-lb at 18 psi.
Old Feb 12, 2010 | 11:21 PM
Slow5.0.'s Avatar
damn.. **** is rolling at 146 and 3750 weight lol. Autos and turbos go so well together.
Old Feb 15, 2010 | 03:08 AM
Slow5.0.'s Avatar
bump anyone else
Old Feb 15, 2010 | 10:08 AM
1998TA__1991RS's Avatar
im putting mine together now, forged ls1, pt76gts truck manifold kit, th400 with brake. should know in a couple weeks how it will do
Old Feb 17, 2010 | 06:59 PM
RICE ETR's Avatar
Turbo Addict
can't compete with the other posters here but numbers in sig made with that turbo, quick spool too.
nice to know I got a good amount of room to grow
Old Feb 18, 2010 | 10:55 AM
airforcemanss's Avatar
wow, that is a nice setup. what gears with the m6?
rice eater, funny avatar
Old Feb 18, 2010 | 11:09 AM
ninetres's Avatar
True......for all turbos that are mis-matched on an engine too large for them lol.
