Pictures of custom rear mount setups?
dont fix it if its not broke
had a friend put a dyno run in my classified ad but i cant figure out how to put it over here
..look at it ,move it what ever
Looks so much better than a nasty big shiny pipe running under the whole length of the car sitting an inch above the ground just waiting for the right speed bump to come along...hahaBut its very ingenious, you should get some inside vids of wot runs for us to see how it sounds to be in there. very curious.
Thanks for sharing
Truck looks goo, but not sure how effective that intercooler location is. Be nice if you stuck a couple of fans on the back of it. Or built some ducking to get air from above/the side of the cab to the intercooler. Should be simple to do with NACA style ducts.
Might be worth having a look at Lonjgranger4U'a rear mount setup. He ended up running 2 sets of stock piping from the turbo to the front end.
Also watch out for Zombie's setup, he is going 3inch on both hot and cold sides all the way from front to back! should be very intresting when finished.
Cheers
Chris.
