Magnacharger kit for LS1 F-body..
#63
I don't drive mine everyday, but I do drive it a good bit. I can get by with rain-x, but I realize for most it would not be practical or legal.
The best bet is a front mounted supercharger, if you are wanting to make big power. Those allow you to keep all the factory options. The other option is to buy a different type car.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I may check into some type of custom wiper option later on, but I am not sure about that. Until they make me take it off the road I will probably leave it as it is!
Later
#65
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Nice job Deeavi, glad someone did it. Yea the TVS2300 is a beast. I cannot imagine what its like in a lighter car. Especially compaired to my TBSS. What pulley are you running on that at what boost level?
#66
#67
The car sure is fun to drive now though!
#72
UNDER PRESSURE MOD
Seriously????
Read his signature, it's right there....
98 Z28 - LSX Block-434, Compstar Crank Kit, AFR 245 LSX Heads, Comp Cams LSR: 621/624 - 235/243 @ .50" -115 LSA, Morel lftrs, Racetronics Fuel System, 63# Injctrs, TF Magnuson TVS2300, Holly 90mm TB, K&N, TSP 100mm maf, Hooker 1-7/8" LT Hdrs, Mufflex 3.5" exhst, Dynomax 3.5" muffler, Magnum TZ 6 spd, McLeod DD Clutch, Moser 9" Wavetrac 3.89 rear, Boyd Wheels, and much much more..........
#73
Seriously????
Actuall my signature is a little off. The maf is just there as a pass-thru, because the tune is an Speed Density.
#74
I checked out Magnuson's website and it shows the TVS2300 to be only .2 tenths of an inch taller than the MP112.
However the 2300 does appear to be about an inch longer and maybe a little wider.
Nevertheless, I still think the 2300 might be doable with K member spacers, and a little more cowl cutting but still able to keep the wipers.
Not trying to argue Deevai, I'm just one of those determined bastards that would really love to pull this off and put down around 800 horses!![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Great build btw. I still want to see the finished product when you get it all straightened out.
Edit: I forgot to mention, the one thing their website does not include is the difference in intercooler height. That may be another hurdle. I'll do some more digging...
#77
I already have most of the parts. My problem is finding the time to work on it. Have a lot going on.
#78
So you put the tvs2300 on a ls1 alu block motor did you ever find out if you can keep the wipers like that one guy said he thought he could do cause I would really like to use this supercharger in the z28 that I want but I know ima have to drop the k member some but also want to keep all the asseserys on the stock motor and would really like to keep the wipers also so it could be lile a dd dose that gto kit really work on the 4th gen camaros so I can fit the tvs2300 and alps what fuel system thing would I also need to look in to doing
#79
Good luck
#80
this has been a great read for me. Im wanting to put a maggie on my 00 ss dosent really matter to me if its the 112 or the 2300 since im doing it mainly for ***** and giggles and to do something other then a procharger.
