How much power can Ls3 block handle..
I agree about the GM heads all of them are thin and will have problems when making big boost or N2O hits.
I think GM rates most of their engines at 500-700 hp. Take a saftey factor of 1.5 and you have the limit
I was told to use ARP l19 Studs & Fel Pro MLS gaskets,
On a side note I have Titanium Intake valves, How are those with boost??
Ive run alot of alum to 1k easy. the ls3 should be at least as strong as the ls2 block
but stock heads sucks all but ls9 then ls7 then 243
1000rwhp should be no issue with good fuel/tune.
stock LS3 block, callies dragonslayer, callies rods, Ross custom pistons, no pinned mains, arp stock size studs, all pro cathedral ports, mast intake, attention to detail, BIG solid roller and real street legal(.082 jet in a plate)
motor made 830hp at 9100 on the dyno, I shift it 8800, it goes through at 8990 that pass.... I am hoping to go in the 7's with it at the shootout.... hope the block will last at least that race....
