Anyone with rear mount TC78 inside please?
Old Feb 18, 2010 | 11:45 PM
vipvegas's Avatar
Default Anyone with rear mount TC78 inside please?
Just trying to compare when your boost is coming on strong. Mine seems to kick in a little later then I expected I guess coming from a 67. I also have an M6 car. Any insight would be appreciated. Think after head swap to 243's Im going to look at a cam other then the EPP. I believe theres room for more power and faster spool times.
Old Feb 19, 2010 | 12:03 AM
mike13's Avatar
Alot depends on the housing A/R.
Old Feb 19, 2010 | 04:37 AM
OUTLAWZ RACING's Avatar
Where dose it come in?
Old Feb 19, 2010 | 09:18 AM
vipvegas's Avatar
With my .96 comes in strong around 4600
Old Feb 19, 2010 | 10:17 AM
mike13's Avatar
How about if you short shift to load the motor? Letting the motor pull a taller gear.
Old Feb 19, 2010 | 11:13 AM
HydroStream6's Avatar
Yea that sounds a bit sluggish... my TC76 with a .81 was strong around 3300... 370ci 9.5:1 comp.
Old Feb 19, 2010 | 04:03 PM
vipvegas's Avatar
Well took it for a good 15 minute cruise. After about the 10 minute mark it wakes up alot faster. Manifolds are wrapped, I still need to wrap all the way back to turbo that should help also might get blanket. Im seeing 8 psi around 4650 when hot
Old Feb 19, 2010 | 06:02 PM
Yeah the wrap and blanket will help it. Im gonna push my rearmount past 1k hopefully with some changes in the future.
Old Feb 19, 2010 | 06:13 PM
vipvegas's Avatar
I believe once I swap the stock heads I got on now, wrap all, and turn on the meth and up boost I should obtain 750+ we will see
Old Feb 20, 2010 | 05:28 AM
I dont doubt it car has strong numbers for 8 psi.
Old Apr 13, 2010 | 02:54 PM
omore001's Avatar
Hey man, rear mounted TC78 with divided 1.15 a/r here, on a 8.5:1cr 370 iron block, 317 heads with dual springs, and EPP cam, 4 speed auto with 4K stall. Full boost at 2500RPM locked in 4th gear, full boost at 4200RPM with converter unlocked 1st, 2nd, and 3rd. I don't have a quick spool valve, just stock LS1 manifolds will all the hot pipes wrapped. Your HP#'s for 8 lbs are much stronger than mine, but I'm sure I'm losing much more through the drivetrain than you are. The 243's will help you spool a little faster. I'm sure you also know about Zombie's quick spool technique, but you are not using a divided housing on your TC78 like I am. If that quick spool valve makes his rear-mounted SX80 spool like a T67, imagine how fast a quick-spool valve will spool up our much smaller TC78's.
Old Apr 13, 2010 | 02:57 PM
omore001's Avatar
I have faith on your set-up and that goal.
