rockers for boost
Old Feb 19, 2010 | 02:01 PM
00bluews6's Avatar
Default rockers for boost
i have a pt88 on a 408 iron block with afr 205 heads and a cam motion 236-230 598/595 on a 114 lsa what rockers should i use i have stock rockers now should i do the comp rebild kit my self or go after market i would like to see 1k hp on good gas its on of my last steps to the build thanks
Old Feb 19, 2010 | 02:16 PM
3rdgen's Avatar
I would have harland sharp rebuild your stock rockers.
Old Feb 19, 2010 | 02:20 PM
BIG_MIKE2005's Avatar
Yep, cheaper than other options out there & have been proven to hold up. Great bang for the buck upgrade.
Old Feb 19, 2010 | 02:26 PM
00bluews6's Avatar
its like $456 for his rockers i can get some comp magnums for less that whats better
Old Feb 19, 2010 | 02:31 PM
It's not if you just send in a cheapo used set, read this link. I wouldn't buy a brand new set outright. You can grab a used set for like $40-60 & send those in.
http://www.harlandsharp.com/conversion%20kit.htm
Old Feb 19, 2010 | 02:56 PM
Rickys S/C Z28's Avatar
hmmm are the stock rocker prone to failing?
Old Feb 19, 2010 | 02:59 PM
BadgeZ28's Avatar
I run the comp cams setup. Full roller rockers, guide plates, adjustable. I have had no problems with them. The 1.75 ratio takes a .550 lift cam up to the .570's
Old Feb 19, 2010 | 03:06 PM
Yes, stock rockers have been known to let loose & allow needle bearings to get into places they shouldn't.
This upgrade from Harland fixes that potiential problem & Comp also offers a kit.
Old Feb 19, 2010 | 06:29 PM
00bluews6's Avatar
has anyone build their own using comps kit
Old Feb 19, 2010 | 06:32 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
If you do use the Comp Kit, you will need shorter bolts. The Harland Sharps are already done, and come with the bolts.
Next up are the Yella Terra's they are a good price. For almost any app, the stockers with upgrade will work.
Old Feb 19, 2010 | 07:11 PM
Shawn @ VA Speed's Avatar
i've seen the stock rockers hold up great at 1200rwhp.We've had a couple of the harland sharpe modded stockers fail.Yella Terra are my favorites.
Old Feb 19, 2010 | 08:08 PM
00bluews6's Avatar
thanks shawn should i stick with the stock ones for now or just play it safe with the yella terra's
Old Feb 19, 2010 | 08:20 PM
i'm always going to reccommend a full roller rocker over a stocker-helps alot with valve guide wear.
Old Feb 20, 2010 | 04:09 PM
03supercobra's Avatar
Just go with some Jesels or T&Ds.
Old Feb 20, 2010 | 06:36 PM
While Jesel and T&D's are the best rockers out there,they are really unsuited for a hyd roller setup.They are rather heavy on the nose raising the possibilty of valve float.
Old Feb 20, 2010 | 06:52 PM
sr71bbjr's Avatar
Not to mention i've seen more jesels break than any other rocker out there.Might have something to do with the setup,but it happends a lot.
Old Feb 20, 2010 | 07:16 PM
I keep hearing about these broken Jesel's but have only ever seen 2 broken rockers-these just had hairline cracks at the tips.I got a couple sets that have over 1000 passes on with 800+ lift cams.
Old Feb 20, 2010 | 07:19 PM
Slowhawk's Avatar
LS1Tech Sponsor
I agree with Shawn. I've built a few combo's extremely close to yours and run stock rockers. The downside of stock rockers is that they will wear down the guides on AFR heads.You can shim the rocker rails up about .040-.060" and it will help the wear problem.
Old Feb 20, 2010 | 08:24 PM
Very interesting, learn something new everyday!
Is this true with all of Jesel's rockers? Or are you only speaking of the SS rockers?
