Getting oil off wrap
Old Feb 20, 2010 | 02:30 PM
XtremeDime's Avatar
Default Getting oil off wrap
I have titanium wrap so its water and oil proof but I had a PS pump go bad and leak PS fluid all over the wrap on my collecter before the turbo. I had the car on for about 30 minutes intermittently (I was afraid the pipe would get too hot and catch fire) and it was smoking a ton and seems to have no end to it lol. Is there anything I can do to help this process along?
Old Feb 20, 2010 | 08:04 PM
DeltaT's Avatar
The only thing I have ever done that actually worked was to remove the wrap and wash it in hot water and a bunch of Simple Green.
Otherwise (like you found out) it smokes for a long time. Maybe go for a long highway drive, like 2-3 hours?
Jim
Old Feb 20, 2010 | 08:30 PM
dimetweaker's Avatar
I was in anchorage yesterday. I dont know how the hell you live there all year.
But uh...as far as your question. I got a pretty hefty amount of tranny fluid in my wrap and it took about 2 hours of constant driving to get the smoke to stop but the smell stayed for a while, so I would definitly try the simple green bath!
Old Feb 20, 2010 | 08:37 PM
XtremeDime's Avatar
I think Ill just spray some simplegreen on the wrap and rinse it off. In the position its at it would be a major bitch to take the wrap off.
Old Feb 20, 2010 | 10:49 PM
KILLER-LS1's Avatar
hahah same thing happened to me! but i melted through the pressure side of the PS lines and shot oil all over the place on the dyno, which caused a nice fire :-/
we got the fire out quickly without too much damage, but now all my wraps are soaked!! i just sprayed 2-3 cans of brake cleaner on them and let it dry after, its still smoking a tiny bit, but not too much.
try the brake cleaner (when the motor is cold)
Old Feb 20, 2010 | 11:51 PM
XtremeDime's Avatar
Ya, ill get some non flammable brake cleaner and see
Old Feb 21, 2010 | 12:22 AM
DeltaT's Avatar
Watch that stuff when you heat it up - if you soak the tape with brake cleaner. Some of it is VERY nasty stuff when vaporized. Saw a welder's story where he got one small puff of brake cleaner after he hit a wet spot with his torch and that little puff caused full kidney failure and some other nasty symptoms. He is never expected to get back to normal.
Jim
Old Feb 21, 2010 | 12:29 AM
elias_799's Avatar
you have the dei titanium wrap ?
By Brett Foote | 2026-06-04 05:00:17
