would like to hear opinions!!
Old Feb 23, 2010 | 03:07 PM
92ZZ3RS's Avatar
Default would like to hear opinions!!
car is a 1992 camaro with a 2002 LS1/T56, moser 9" rear 3.70 gear, T.E.A. LS6 stage 2 heads, 11:1 compression, VRX4 cam 228-230 588-592 113+2. want to go single turbo. me and friend will be doin all the work. i know what turbo he has recommended but i would like to hear opinions on what you guys think. which turbo and why, injectors, most boost to be safe, etc. the car is not a daily driver but is street driven when it goes anywhere. jose, you can chime in too. u know the car ;-)
Old Feb 23, 2010 | 03:22 PM
DeltaT's Avatar
I would go straight to 75# injectors. I would also bite the bullet and change pistons. Do it right the first time. Get your CR around 9.2 - 9.5. If you stay at your current CR, even with meth injection and a nice IC I would say 6# as an upper limit.
Jim
Old Feb 24, 2010 | 09:06 AM
92ZZ3RS's Avatar
come on guys
Old Feb 24, 2010 | 01:45 PM
chase3's Avatar
Jim
For sure with that CR not over six pounds. I was 11.5 CR and forged and still burnt a hole in 3 pistons on 6.5psi. Ecspecially with stock internals you will just have a ticking time bomb. I would put 317 heads on it to lower the compression and then you could run more boost
