Vortech G Trim
Old Feb 24, 2010 | 03:53 PM
02PewterZ/28's Avatar
Default Vortech G Trim
Does anybody out there have any horsepower figures from a Vortech G trim with aftercooler on an otherwise stock M6 LS1 with just a catback? It will probably make 8-9 psi on a stock motor I assume.
Old Feb 24, 2010 | 07:11 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah they make about 460-480rwhp in stock form. And can make about 550rwhp pretty easy with a pulley swap fuel injectors and tunning.
Old Feb 25, 2010 | 10:42 AM
I am going with 60# injectors for room to grow and a custom tune.
Old Feb 25, 2010 | 08:02 PM
cputech's Avatar
I love mine
Old Feb 26, 2010 | 04:56 PM
phatasp's Avatar
me too
Old Feb 27, 2010 | 03:51 PM
What kind of hp numbers are you guys putting down?
Old Feb 28, 2010 | 09:39 AM
phatasp's Avatar
I,ve got dart heads and a fast intake and throttle body,When I first put the supercharger on it dynoed 488/524 with the trans going out. raced it that weekend it ran 11.90 before the trans said goodbye. I changed the trans tried it again and went 11.20 so I,m thinking a little over 500hp a4 trans,9inch rear
Old Mar 1, 2010 | 12:06 AM
TransAmatt99's Avatar
Before I did my swap mine had a 2.95 pulley and it was around 8-9 psi with a set of 317 unported heads, ls6 intake, and full exhaust it was right at 500rwhp. If you did a g-trim with heads/cam it would put your stock bottom right at rod breakage territory.
Old Mar 1, 2010 | 06:46 AM
phatasp's Avatar
I,m running about 8or 9lbs,I,ve only ran it about 15 times but sooner or later I,m sure I will be looking for a forged bottom end. No problems so far though.
Old Mar 7, 2010 | 08:07 PM
boosted4life's Avatar
450rwhp stock with a blower. I know a guy putting down 550rwhp bone stock with longtubes and a g-trim on 9psi with e85. I put down the same numbers with a cam, full exhaust, ls6 intake manifold and 8psi on 91 octane. Same blower.
Old Mar 12, 2010 | 12:48 PM
Bansheetwin360's Avatar
^^ I am the 550 hp guy lol..
I have a bone stock motor valve covers never been off the car 60# injectors a single walbro 255 in tank <3 E-85..
Make sure you have your crank keyed if you get a supercharger setup though
