looking for an a good spring pelt tensioner
Old Feb 25, 2010 | 01:48 AM
red 454's Avatar
Default looking for an a good spring pelt tensioner
im looking for a good 8 rib SPRING auto belt tensioner not interested in the Manuel adjustable one for ls3
does any in the USA make one
i cant by them in oz
only the OEM one and change the pulley not real successful on an an 8pk PD system
Old Feb 25, 2010 | 02:33 AM
MFIC's Avatar
This might work http://www.eastcoastsupercharging.co...tensioner.html
Old Feb 25, 2010 | 02:51 AM
red 454's Avatar
Originally Posted by MFIC
thanks for that i did email them and they said it is for corvette fitment it looks a lot differant to mine
pic of mine with a streatched belt it is siting on the stop
as you can see my pulley doesent stick out from the block on a bracket and the spring housing on theres looks very much like a stock one ?
so my be just a diff bracket with a stock spring cage witch i can by here
Old Feb 25, 2010 | 09:29 PM
Johnv's Avatar
going by the pic you need a new or smaller belt, as the tensioner is all the way back against the stop and that will be whats rattling.
Old Feb 25, 2010 | 09:34 PM
red 454's Avatar
no its not thats a pic of it WITH A TO LONG A BELT
that harrop sent in the kit it has a 40mm shorter belt on now and the adjustment is 99% the other way
yes it did rattle like **** with the long belt never even drove it with that belt
Old Feb 26, 2010 | 01:41 PM
DeltaT's Avatar
Dayco has a lot of tensioners here:
http://www.daycoproducts.com/daycowe...nerCatalog.pdf
These are their heavy duty versions and are built to last 1M miles. I have used some of their pulleys in my build and they are high quality.
Jim
Old Feb 26, 2010 | 02:06 PM
red 454's Avatar
Jim
thanks for that they look good
do they do one for ls2/3 ?
would you have the part #
thanks
Old Feb 26, 2010 | 03:56 PM
lmt0705's Avatar
do you want a spring tensioner? katech makes a really nice billet peice that eliminates the spring and prevents the belt deflection and belt throwing
Old Feb 26, 2010 | 07:25 PM
red 454's Avatar
Originally Posted by lmt 0705
do you want a spring tensioner? katech makes a really nice billet piece that eliminates the spring and prevents the belt deflection and belt throwing
no i dont want a solid one plenty of them over hear
i want a spring loaded one we have proved here that the belt stays tighter (less slip) with a spring loaded one when the belt stretches under WOT the solid one lets the belt slip
you would have to tighten it up at wot and then it would be to tight at idle
and they are very hard on the bearings on the blower drive and the other pulleys bearings
Old Feb 26, 2010 | 07:56 PM
1blownss's Avatar
760-522-8669 This guy's name is Joe ...he made this tensioner and several others over the yrs ...They are great and I have never seen anyone that bought one of these ever have a problem ...Give him a shout and let him know what you are looking for ....Good Luck
Here is his email form and his website . http://www.leftcoast32.com/contactus.asp
Old Feb 27, 2010 | 12:01 PM
DeltaT's Avatar
The one in the picture above is probably a Dayco unit modded to fit. I don't have an LSx P/N. You have to find a friendly parts guy and look at his Dayco catalog for more details.
Jim
Old Feb 27, 2010 | 01:46 PM
red 454's Avatar
Jim
IN OZ the catalog only shows a pully only for v8 ??
no tensioner
