Boost leak
Then I pressurised the whole intake from turbo to heads, was quite surprised to find I couldn't get it to hold any pressure and air was escaping rapidly around the injectors on one bank, also from the base of the manifold, the mezier water pump was hitting the manifold and preventing it seating properly.
Anyone else come accross boost leaks from injector o'rings ?
It may be an alignment issue due to the budget fuel rails i have,
but the o'rings don't feel that tight in the manifold either.
Is it possible to get a slightly bigger OD injector o'ring ?
Looking at replaceing my rails with CNC billet jobbies that have the manifold mounts machined in all as one. Should give better alignment and be more ridged and not flex under boost.
Would also like some slightly bigger OD injector o'rings if they are available.
