where do you mount the o2 wideband on a rear mount turbo?
So your wideband O2 sensor sits 2" from the exhaust tip?
When you say "I" pipe do you mean after the duals come together? sorry for the retard question. I was reading that most put it on the drivers side....or maybe it was on the passenger side....which ever one was because one bank ran leaner than the other. I am all ready to drill but i was hoping that more people were running theirs before the turbo.
was wondering, on the rear mount widebad o2, does it matter if its 2" after thr turbine or 14" ? reason i ask is that im getting a resonator with an 02 bung on it and depending on the orientation puts the bung at either of the distances mentioned above.
in a rear mount, depending on your pressure ratio and turbine, your exhaust from the block TO the turbo can be a few psi. this will cause them to do funny stuff.
at the outlet of the turbo it is just slight positive pressure, especially if you don't have a long exhaust run.
I put my wideband 8 inches after the V-band at the turbo outlet
