Newbie Speed Density vs. MAF
1 bar is 14.7psi which is what we have at atmospheric level. You would need a 2 bar sensor for 0 to 14.7 psi of boost and a 3 bar sensor for 0 to 29.4 psi of boost.
because you pushing more air into the motor, the PCM has to compensate by adding more fuel. Atleast w/ a turbo setup you can control the boost better than a S/C. When ever it gets cold out the air is denser and you can see the boost levels go up.
Last summer mine was making 10# and on a cool Nov night, I was seeing 12-13#.
To be safe though, get it checked and tuned if necessary.
