New KY-TURBO shop car.....
#142
im sure that fixing the leaking gate will prob make a big difference, but a housing change seems logical. best thing is to wait and see what it does with everything working properly.
#144
Good talking to ya today Ricky. I will give ya a shout when I get home from Vacation. The WG ring will help out alot. The tune is gonna be key as we talked about earlier. That Turbo is well proven on the Platform you are running. No worries there.
Appreciate the copy of that PM too. Funny **** right there.
#146
WELL dynoed the car tonight, car makes good power but the power band is wrong. On low boost(11psi) and pump gas no meth. made 677/5xx!!!! the thing take a minuet to get wined up but then it pulls like a freight train!!! Would have been nice to get it to make 16 ps1 on the dyno but we had a hard enough time getting it to spool up that much LOL out on the road we could make to pull to 16 psi!!! sure would be nice to see what kinda power it would make at the boost level! from what i can see im going to need a different housing and maybe a smaller cam.
#147
LS1Tech Sponsor
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
http://www.youtube.com/watch?v=yXY2RttIAQ4 Video
5/17/08 Update:
Randy brought his Z06 back to us to have us install a larger fuel system in it, so we could up the boost. We hadn't seen Randy or his Z06 for years, so it was nice to have them back, and it is nice to see the 'lil 346 was still running strong! This time around Randy's Z06 got tuned with our EFI Live software, instead of the LS1edit we use to use. That tells you just how long it has been since we built this car!
Once again we had a tough time getting traction on the dyno. We used extra straps to draw the rear tires down on the dyno rollers and Randy's 335's would still break loose. We did manage to get 851 rwhp, had the tires not broken loose and unloaded the turbo's, we are sure we would of seen a lot more power.
![](http://i226.photobucket.com/albums/dd185/EPP_photo/Randy860.jpg)
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#148
im not sure what it is yet. with the WG open we cant get more the 16 psi, the thought that we are having is that it is bleeding off to much boost. not sure yet.
#149
Dont be so Quick to change the housing. I have seen as much as 40+ degrees of timing down low to get big turbo's to spool on small engines. It is a numbers game. Have you all changed the spring in the WG?
#150
josh my phone is broke right now so i cant call you . but if you wan to can call me. we had over 30 degrees in it and it still is haveing a hard time spooling. but man this thing is crazy on the street. lol
#151
look at quik 's setup. 4.8L cam is around the same as yours, and he has a PT88 on it and was spooling it decently easy. The turbo isnt your problem, look elsewhere. Blown out header gasket, timing, wastegate fuel, etc.
#152
Hey Ricky I say talk to 98Z28CobraKiller. He is very smart on this stuff. I have followed a lot of his threads on here. Plus he taught me a lot. So check him out and drop him a PM.
#156
car ran great! went a 10.64 @ 142 with a 2.63 60 ft!!!!!! but on the way home a rod came lose started to make a little bit on noise so i shut her down. had Blue cat check it out and it deff a rod i just hope its not that bad. but its back to the drawing board for now
#157
