Did i mess up the rear main?
Drivers valve cover to vented catch can, then from catch can to pass rear valve cover.
Front of pass valve cover to pcv valve to catch can, then from catch can to check valve then to intake port
Capped off the TB port. Not running a line to the inlet either.
Not sure if there is much truth to this, but I was told that if you keep on messing up rear main seals it could mean the crank shaft isnt properly balanced.
. If that rear main is the problem. The stock 113k motor is coming out to get freshed up.
