my home built gt-88 setup
Old Mar 8, 2011 | 01:24 PM
  #41
Fireball's Avatar
I use the basic couplers from vibrant performance. Need the style with the interlock inner liner (not the mesh inner liner). I've used this in the past with no issues. I put on on both sides on my setup, but thats probably overkill
Old Mar 8, 2011 | 02:00 PM
  #42
navyblueSS's Avatar
Nice work, looks good!
Old Mar 8, 2011 | 02:01 PM
  #43
PRAY HRD's Avatar
Originally Posted by fastbillet
Yeah thats what i was thinking....so there is no leakage like a spd?
Or leakage like a sTd! LOL Sorry, could not resist!!
Old Mar 8, 2011 | 10:21 PM
  #44
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
^ Ew...
That's a nice setup. I like the intercooler mount although it looks a little heavy compared to how most people mount them. There's nothing wrong with a little overkill.
Old Mar 9, 2011 | 10:58 AM
  #45
fastbillet's Avatar
THANKS FIREBALL! i called josh up yesterday afternoon and he said with a solid frame mounted turbo and solid motor mounts i will not need to add a flex joint.... he said he has done it numerous times without breakage as long as the weight from the turbo is 100% supported from the frame... should have more pics up tonight of the intercooler installed with piping and the rear end all mocked up
Old Mar 9, 2011 | 11:01 AM
  #46
Fireball's Avatar
still not a bad idea...makes installing crossover easy and it gives it some room to move when it thermally expands.
Old Mar 9, 2011 | 12:26 PM
  #47
fastbillet's Avatar
thats not a bad point...
Old Mar 9, 2011 | 05:13 PM
  #48
Taubr Unit's Avatar
subscribing.... sweet build and nice work!!
Old Mar 9, 2011 | 05:52 PM
  #49
GhostofKrypton's Avatar
what size down pipe is that? and are you running a turbo K member. nice build!
Old Mar 9, 2011 | 06:52 PM
  #50
fastbillet's Avatar
bmr turbo k-member and 4" sir!
thanks tabur! ur ride looks sweet as well im right down the street in lagrange car is being built in my shop at billet specialties.... stop by if you want!
Old Mar 9, 2011 | 07:01 PM
  #51
Taubr Unit's Avatar
no **** huh?! We (my work guys at Stone Mountain Access) bought a bunch of stuff off you guys and picked up some stuff at the shop and i do believe you should know my buddy Dan, he owns MidWest Custom and does custom paint. But yea id love to come by and check it out before i do my hotside and shoot the **** for sure! PM me a number and ill shoot ya a text
Old Mar 9, 2011 | 07:05 PM
  #52
John H's Avatar
E-85 all the way! much better numbers then 93
Old Mar 10, 2011 | 12:54 AM
  #53
fastbillet's Avatar
yeah dizzle! lol crazy! he painted my jetski im building hes a legit dude for sure small world
Old Sep 27, 2011 | 03:49 PM
  #54
fastbillet's Avatar
Anyone have any pics of where to drill oil pan for turbo oil return line? If so post up my turbo is located where the battery was... Also what size an lines are you guys running to the vented catch can from the tops of the valve covers i need to drill and tap the valve covers since the motor and trans is going in this week!! Full bmr frunt suspension is finally installed
Old Sep 27, 2011 | 05:41 PM
  #55
Build-it-Break-it's Avatar
I saw that your venting the wastegate to atmosphere, I read an article that sometimes the turbo will suck in the wastgate gases when vented into atmosphere threw the filter. When this happens your blowing back exhaust fumes into your intake, robing Horse Power. They did a test with one vented to atmosphere and one routed back to the main exhaust pipe. They had a power loss of 60hp when vented and a 100hp gain when routed to the exhaust down pipe. I personally don't know if its true but its worth looking into seeing as how your reaching for 1000hp. Every little trick helps. Nice Build!!
Old Sep 27, 2011 | 06:03 PM
  #56
ls1curt's Avatar
Build looks awesome. I put my return in the bottom of the front cover, to one side just enough to clear the crank pulley. For the catch can, I ran 8an from the front of each valve cover to the catch can.
Old Dec 29, 2012 | 12:32 PM
  #57
Punisher_ws7's Avatar
any updates on this old thread?????
Old Dec 29, 2012 | 01:27 PM
  #58
Bobsmyuncle's Avatar
idk if its been said yet, u might wanna up that gate to a 60mm. i got a 50 mm on my gt4788 and it doesnt go below 18#s
Old Feb 2, 2013 | 10:59 PM
  #59
fastbillet's Avatar
Cars getting finished as we speak lost interest and put it in the corner for a while... Should be running in a few weeks running pro efi now... Also getting cage installed and motor and trans is all assembled and joined...
Old Feb 3, 2013 | 01:24 AM
  #60
westtexasbuff's Avatar
Nice... Not sure what you went with on rear end and fuel setup... but here's mine if you need ideas... FAB 9, custom fabbed 25 gallon fuel cell, and magnafuel 4303.
