High Flow LSx Injectors All Flow Matched
Old Mar 18, 2010 | 07:20 AM
JeremyF's Avatar
LS1TECH Sponsor
Default High Flow LSx Injectors All Flow Matched
We now are offering high flow injectors for Just about any LS based vehicle in need of a bigger fuel supply for all that additional horse power you have added or are going to add.
We now have available GM factory re sized injectors for LS1/LS6, LS2 and LS/7's that are flow matched and upgraded to support 750 + horse power applications.
Please call us at 813 476 7364 for Visa, MC, and AMEX payment, or you can Paypal at fastprom@tampabay.rr.com
If you use Paypal, please include your shipping address or reply back here with it.
Our shipping address is
Fasterproms
19103 Sunlake Blvd
Lutz, FL 33558
LS2 72lbs:
$325.00 shipped - lower 48.
Perfect for any LS2 car in need of more fuel with no adapter's needed, will also work with LS1 and LS3 but will require either spacers or injector connector adapters. Able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi, where as LS cars run 4 bar at 58psi, which on LS fuel pressure of 58 is 72.25lbs. If needed we may be able provide the adapter kit based on your specific application.
LS3 72lbs:
Perfect for any LS3/L76/LS7 car in need of more fuel with no adapter's needed, will also work with LS1 and LS2 but will require either spacers or injector connector adapters. Able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi, where as LS cars run 4 bar at 58psi, which on LS fuel pressure of 58, is 72.25lbs.
LS1 48lbs:
$300.00 shipped - lower 48
We can provide an injector flow rate slope for these injectors.
Old Mar 18, 2010 | 07:53 AM
CarsandWomen's Avatar
do you sell the adaptors to put ls2 injectors on an ls1? im looking at the Nasty Performance stage 2 kit and am wondering if these injectors will work with it, going on a 98 ls1
Old Mar 18, 2010 | 09:16 AM
JeremyF's Avatar
LS1TECH Sponsor
We sure do, a set of the height and wire adapters runs $96.00. Together with the LS2 72lb injectors would be a total of $421.00 shipped. Give us a call if you would like to order at 813 476 7364.
Thanks
Dan
Fasterproms
Old Mar 18, 2010 | 09:48 AM
bonnarls1's Avatar
is that the highest you can go???? looking for some 120lbs or higher
Old Mar 18, 2010 | 09:50 AM
JeremyF's Avatar
LS1TECH Sponsor
Tell me specifically what you are looking for and the application?
Thanks
Dan
Fasterproms
Old Mar 22, 2010 | 11:27 AM
JeremyF's Avatar
LS1TECH Sponsor
Monday bump TTT - WE can also have a custom set made for your application.
Old Mar 28, 2010 | 08:17 PM
going to call and order a set in the morning, free bump.
Old Mar 28, 2010 | 09:34 PM
Ping King's Avatar
so the ls1 42 lb are tested at 43 psi also?
