World's fastest Ebay Kit!
Old 03-24-2010, 05:14 PM
craig382ci's Avatar
CR good for running high boost pending on the fuel setup. What's your fuel setup?
Old 03-26-2010, 03:54 PM
z28boysteve's Avatar
I'll be running some sort of race gas for an extra margin of safety I'll add 2 degrees of timing over pump gas prolly to make up for it or run a race gas/93 mix
Old 03-26-2010, 04:09 PM
99Ls1fever's Avatar
Wow, That is going to be a sweet track car What motor mods do you have???
Old 03-27-2010, 04:11 PM
I posted that a few replies ago
Old 03-27-2010, 04:35 PM
MelScrilla's Avatar
Are you still running the stock LS ecm?
Old 03-27-2010, 08:29 PM
Sure am with 95 lb low z acceleronics injectors and a 2 step piggybacking it
Old 05-03-2010, 07:16 AM
Last bit of wiring, install transmission, install a2w cooling system,
and a water pump outlet modification is all that remains! Not much longer now.
Quick Reply: World's fastest Ebay Kit!
