alternator relocation bracket
Old Mar 20, 2010 | 07:57 PM
pdasterly's Avatar
Default alternator relocation bracket
Can the larger truck alternator fit with the alternator relocation bracket the puts the alternator on the top passenger side of the engine?
Old Mar 21, 2010 | 08:26 AM
smokinHawk's Avatar
Yes if you remove power steering and have to cut off a large part of the bracket
Old Mar 21, 2010 | 10:43 AM
pdasterly's Avatar
Why would the power steering have to be removed, I want the bracket that puts the alternator over the factory tensioner on the passenger side valve cover
Old Mar 21, 2010 | 12:20 PM
smokinHawk's Avatar
Oh sorry I thought you ment the truck alt bracket
on my truck 00 serria it's the same alt asy my 99 transam
Old Mar 21, 2010 | 12:25 PM
1998TA__1991RS's Avatar
im using the large truck alternator on mine up there, except i made my own bracket
Old Mar 21, 2010 | 12:58 PM
pdasterly's Avatar
got any pics? the bracket i purchased looks like this
Old Mar 21, 2010 | 04:44 PM
here it is, you cant see it but the bottom side is braced to keep the alt. from twisting. its sturdy as hell, but keep in mind im running an electric wp and no power steering, so i just run a short belt. also i have a pin on ws6 hood so i have enough clearence to mount it up a little higher
Old Mar 21, 2010 | 04:51 PM
transammiller's Avatar
Restricted User
i have the speed inc bracket. sturdy and looks great!. a bit pricey but well worth it.
Old Mar 21, 2010 | 04:55 PM
pdasterly's Avatar
nice, I looked at the speed inc option, but my problem is I need the biggest alternator i can get in there for cheap. I want to use a 300 amp cs-144 case alternator(truck alternator)
Old Mar 21, 2010 | 05:40 PM
smokinHawk's Avatar
If that alternator is from the BBC vortec 8.1 v8 I'm not sure it will fit
if it's from the gen3-4 ls- style like the 4.8, 5.3, 5.7, 6.0, 6.2 etc it will fit
but I think your talking about the BBC alt.
Old Mar 21, 2010 | 07:20 PM
Restricted User
the speed inc bracket uses a 105 amp from a 90s suburban.
Old Mar 21, 2010 | 07:40 PM
van383's Avatar
i use machine head set-up and my alt guy made my late model alt 140 amp one wire..
Old Mar 25, 2010 | 07:01 AM
1badsuv's Avatar
katech makes a really nice setup. i had a bunch of ones made but finally went with the lt1 alternator and their bracket. best setup so far.
Old Mar 28, 2010 | 07:51 PM
ohshixgoat's Avatar
who all makes these brackets? I only can find one on speed inc. site. I have one but I think its junk. also Is it neccesary to remove the belt tensioner?
Old Nov 5, 2010 | 02:04 PM
67Firebird455's Avatar
Sorry to revive an old thread but I got my SmokinHawk bracket (that i've had for quite some time lol) installed last night on the 67. Thought it'd be worth showing some pics of it installed. Will need to get a belt for it but need to clean up the PS pump/bracket first before I install it on the head.
Attached Thumbnails alternator relocation bracket-img_0998.jpg   alternator relocation bracket-img_0999.jpg   alternator relocation bracket-img_1001.jpg   alternator relocation bracket-img_1002.jpg
