Legit 8 sec street car
Old 03-23-2010, 07:12 AM
  #61
Restricted User
98Z28CobraKiller's Avatar
Originally Posted by gnx7
You must've been smiling ear to ear when you made those last 2 passes!
What intercooler are you running again? Treadstone or eBay?
Also you are running stock PCM with an injector box?
What rpm are you crossing the line at?
-Mark
Intercooler is custom from Speed Inc, I believe. I bought used NIB. My understanding is that it has a Bell core 24X12X6. It's as big as you can fit under the bumper support.
I am currently running the stock PCM but I wont make another pass down the track at this power level with the stock junk. I'm just holding out for the MegaSquirt3X right now. I have high imp 80# inj so no driver box.
7250 ish RPM at the finish line.
Old 03-23-2010, 07:19 AM
  #62
raymond mckinney's Avatar
Glad you guys had a great track day. I was going to come but i seen 80% and its a 3 hour and 40 minute ride so i backed out...
Old 03-23-2010, 09:08 AM
  #63
LS1Tech Sponsor
Mike@Diablosport's Avatar
Awesome accomplishment, congrats.
Any idea where those injectors are at duty cycle wise? Figure you must be making some serious power, guessing 1000 rwhp or so at that weight?
Old 03-23-2010, 09:18 AM
  #64
99Ls1fever's Avatar
Congrats That Car is Insane
Old 03-23-2010, 12:14 PM
  #65
Restricted User
Damn man. Too bad you didn't make it out. It turned out to be a great day. Didn't rain until 4:30PM.
I'm seeing 85-88% duty cycle at about 73 psi fuel pressure on the 80# injectors.
Old 03-23-2010, 12:39 PM
  #66
FLA 98TA's Avatar
Grats again man. Injectors can be ran pretty hard
Old 03-23-2010, 04:40 PM
  #67
Gingervitis Addict
slow67's Avatar
I saw it was released yesterday.....(diyautotune)
Old 03-23-2010, 04:49 PM
  #68
lmt0705's Avatar
was that on your 325/50/15 mickeys?
Old 03-23-2010, 04:59 PM
  #69
ZL1Killa's Avatar
Hell yeh man!!!
Old 03-23-2010, 05:36 PM
  #70
Snyper's Avatar
Wow. Simply amazing. Good job man.
Old 03-23-2010, 06:00 PM
  #71
Mike454SS's Avatar
Thats really cool, congrats man. One of the more impressive video's I've seen.
Old 03-23-2010, 07:13 PM
  #72
Restricted User
I been in contact with Matt Cramer daily trying to iron the details. Never done one. We are going to do the first one on BonnarLS1's car. It is a simple, straight forward, NA application. Should give us a good A to B comparison. MS3 was released but sold out in like 12 hours. The MS3X board is not yet available for consumption from what I have understood.
Old 03-23-2010, 08:42 PM
  #73
fenix999's Avatar
8's man!?!?!? hows the alternator relocation bracket holding up? wow i havent been on here in a while but thats ****** sick. Congrats again this gives me all the motivation i need to finish mine ill definitely do some cartwheels if its half as fast as yours!
Old 03-23-2010, 09:39 PM
  #74
reamo04's Avatar
congrats man!
Old 03-25-2010, 08:19 AM
  #75
MY99TAWS6's Avatar
More details please..
Turbo 350..what gears, what make and stall details?
Trans brake? Two step?
What suspension mods done to car..shocks, front and rear sways,springs,torque arm..
What boost controller, any boost ramping?
What fuel octane..alc/meth? race or pump gas.
What tires.
Congrats on the time. I will be super happy to hit a 9.xx even 9.99 with my car this season.
So your track is pretty lax.Or do you have a full legal cage and all the other required stuff, parachute,etc.
Old 03-25-2010, 08:23 AM
  #76
MY99TAWS6's Avatar
Oh what head gaskets are you running.I went with ls7 but they are not great match in the steam holes and might have some problems so was thinking over next winter ,sooner if have too would go to ls9 or possibly some cometics? I will be running no more than 20psi max.I have arp head studs ,standard ones. Any water pushing on your car?
Old 03-25-2010, 01:09 PM
  #77
gnx7's Avatar
can you elaborate on the trans build and what convertor? Amazing it can take the abuse and at that weight/power level.
Old 03-25-2010, 01:10 PM
  #78
Restricted User
What tires.
Th350 w/ RMVB and Transbrake - Built by Doug's Transmissions built 6/2007. Has Red clutches and JW HD intermediate sprag/drum assembly and the B&E Tbrake & Vbody. Everything else is stock. This transmission has seen more wheel stands than I can count. It has far exceeded any expectations that I had for it. It's about time for a glide.
FTI Torque Converter - Purchased at the same time as the transmission. It has been thru several different motor configurations. Greg at FTI is the The Man. He has restalled it several times and it's due for another restall. He takes great care of me as I have helped him corner the converter market in this area. It is stalling to about 5200 RPM which is ok but the shift extension is only at about 400 rpm. Definetly a couple MPH left in the converter.
2 Step - Lingenfelter LNC-003 set at 3600 RPM. Builds about 6-7 psi on launch. No timing modifications currently in use.
Boost Controller - AMS500 with CO2. 10# of CO2 on the gate at launch ramped over 4 tenths to 31# at full (19#) boost. I think that the fact that I need 31# on the back of the gate to build 19# of boost tells me that I have too much back pressure. I think that I would benefit from a larger backhousing.
Fuel - 93 octane up to 15 psi. For these passes I was on Maximal 116. It's mostly for some peace of mind. No meth. 17* of timing.
Suspension Front - QA1 "R" front shocks and the 275 springs. BMR Turbo Kmember, stock A Arms and no sway bar.
Suspension Rear - Jegster adj lower control arms, Jegster adj torque arm, BMR adj panhard, Eibach stiff springs, Comp Engineering 3 way adjustables in the rear and a S60 rear with 3.54:1 gears and a TruTrac.
Tires - Mickey Thompson 325/50/15's Drag Radials at 19psi (I think). Been a while since I checked the tire pressure.
Safety Equipment - Lap belt and helmet. This is one of the things that I am changing. The track is lax but not this lax. I get special treatment but they break my ***** every chance that they get. I am going to do a roll bar to start and see how it goes.
Standard ARP studs and stock 6.0 head gaskets with the AFR225 heads.
FAST90 and NW90 throttle body for induction.
Old 03-25-2010, 01:20 PM
  #79
reamo04's Avatar
you still have some left in it too! Get a diff exhaust housing to drop the back pressure, and get some tubular A-arms
Old 03-25-2010, 01:33 PM
  #80
obZidian's Avatar
Congrats on the PB! Getting it down....
Tech at PBIR is decent and they don't get to tough BUT they will let you know what your missing. Had one of them give me **** about the Z...
You're in the WBP area or further south?
EDIT: Time to change that "10 second club" to "8 second club"!!
Quick Reply: Legit 8 sec street car
