What intake manifold? PT88+22psi
Old Mar 22, 2010 | 09:07 PM
TRMIN8R's Avatar
Default What intake manifold? PT88+22psi
I got a few good runs in with the LS6 intake on my car on high boost(22psi), but it blew the plug out of the back on my last pull at the track yesterday. Is there a way to make that plug stay in or do I need a different manifold? Has anyone used plastic epoxy to keep it on? I'd like to keep the stock manifold if possible but if not, what intake manifold works best for boost? Thanks
Motor is a 370, TSP terminator heads, pt88 turbo, th400, etc...
Old Mar 22, 2010 | 09:22 PM
longrange4u's Avatar
I would say the Edlebrock...
Old Mar 22, 2010 | 09:41 PM
corpserodeo666's Avatar
Yep, The Vic. JR with a sheet metal elbow for the win!
Old Mar 22, 2010 | 09:48 PM
TRMIN8R's Avatar
Is there an elbow available that fits without cutting anything?
Old Mar 22, 2010 | 10:02 PM
MIGHTYMOUSE's Avatar
hmm weird. never heard of that before. had you removed it before or was it in wrong? did it break the intake?
ive run a couple different ls6 intakes to 23-24 lots of times.. maybe you should just try another one?
Old Mar 22, 2010 | 10:13 PM
In case you dont know... MM drives the fastest true DD on this board (8sec)... I would take his word!
As for the elbow... yes... there is a sponsor here that sells em even!
Old Mar 22, 2010 | 10:26 PM
'Trust''s Avatar
The LS6 intake is generally good for a lot of boost. However, I'd go with Vic Jr. and a good elbow (aka, not the Edlebrock elbow), mine was an intakeelbows (Google) elbow milled down to fit under the cowl:
Also, good to meet you in Houston!
Old Mar 22, 2010 | 10:43 PM
laughatrice's Avatar
I just switched from a FAST to a ported LS2 after I cracked my FAST. The main reason I went LS2 was so I could retain my 90MM throttle body. I would think a ported LS2 would out perform a LS6 but who knows. I was afraid of how the elbow on the vic jr would flow.
No LS2 #'s yet though.
Old Mar 22, 2010 | 10:44 PM
daniel6718's Avatar
id assume it was a freak incident...put some kinda glue on it and put it back in there...although a carb style and elbow would be kool...just money that you dont need to spend IMO
Old Mar 23, 2010 | 12:34 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
The vic jr. is the popular choice. The GMPP intake is slightly shorter so you could fit a better elbow on that if you are concerned with clearance.
Old Mar 23, 2010 | 09:44 AM
TRMIN8R's Avatar
Thanks for the replies. I'm not sure if the intake is cracked, haven't pulled it off yet. But if its not I think ill try glueing it in.
Old Mar 23, 2010 | 07:26 PM
daws222000's Avatar
Default intake
I have a victor jr with a elbow from aaron at intakeelbows.com and it looks bad ***.
Old Mar 24, 2010 | 02:55 PM
gnx7's Avatar
Has anyone tested power gains going from an LS6 intake and ported stock TB to an LS2 with a 90mm TB?
I'm curious as my plan is to run an LS6 intake with a GT88 T6 turbo on a 364ci setup.
Old Mar 24, 2010 | 03:12 PM
Trans Am Jam's Avatar
throwing 10-16lbs of boost at a ls6 intake should be fine though right guys?
Old Mar 24, 2010 | 03:19 PM
XtremeDime's Avatar
What about a Weiand? Arent those aluminum?
Old Mar 24, 2010 | 07:34 PM
TRMIN8R's Avatar
Just got the intake off and it is cracked in the back right under that plug. What would cause this? Timing is at 16 degrees, I was on 22psi, and shifting around 6400. Also c16 gas
Old Mar 24, 2010 | 09:21 PM
that sucks man i dunno what the deal is.. sorry.
Old Mar 24, 2010 | 09:47 PM
TRMIN8R's Avatar
I'll prolly just go ahead and get the super victor and be done with it. I don't wanna get another ls6 and have it break too, that's my luck lol. Thanks for the help.
Old Mar 24, 2010 | 11:04 PM
Ws6kid.'s Avatar
ive seen and herd alot of good things from the vick intake.
Old Mar 24, 2010 | 11:52 PM
TPRDFW's Avatar
i dont see how it would be the intake man? do u use anti seize on ur plugs? id make sure them are tight as fuckkk
