What intake manifold? PT88+22psi
You will definately have to cut stuff with the Super Vic. The Vic Jr. and an elbow sounds like what you want.
Yeah, but it bolts in. Plus I'll epoxy the rear plug before I put it on. I really don't care for the way vic jr's look. And I don't wanna spend 300 bucks on an ls6 that could break again. If the ls1 intake breaks, oh well, just buy another one for 50 bucks.
Sounds good. The single plane's looks can be argued and you'll have to modify your charge pipe to it to deal with the different angle/length requirements but, eventually for a turbo setup, the single plane will allow you to really push that charged air into the motor and build solid power as rpm's increase.
#32
LS1 and LS2 intakes are not one piece intakes. The air will bleed from cylinder to cylinder when it "grows" under boost. The LS6 is a one piece which is why it works so well under boosted applications.
#35
The BBK LS6 Intake could be a good option for you as well. Supposed to be as good flowing as an LS6, but with the robustness of aluminum.
There are a few threads on here where folks lost ET in FI applications after switching to Vic Jr. I think one even had a before/after dyno that showed a slight gain near redline, but a loss all the way up to that point. May be worth it just for the coolness factor though.
#36
the c5 ls1 intake dont have the egr bore and look just like ls6. but dont flow the same. can find them for less than 100$ shipped usually. have pumped over10psi thru them w/o any prob. dont know about 20+ tho.
#39
#40
Well I put the LS1 intake on with a rubber plug covered with a bracket I made. Ran it on the street yesterday and it seems to work just like the ls6 on 13psi. I'll leave it on this boost level until I get a BBK, then it'll be turned back up. I'll let you guys know if I still run the same et's/mph with this intake.
Rob, I picked up that intake from Solid, thanks man!
