Crank Pinning--Newb Needs Help
Bolt doesn't tighten down against fixture:
But anyway, you have the right idea there. But you can't use that long as procharger bolt lol. Use your stock bolt to tighten it up. Also those bolts that thread into the fixture are to keep the fixture from going to far up on the crank. You should be able to snug it up on there until the bolts hit the end of the crank.
So, after reading your write up (thanks for that and thanks DanDan for finding it)...the bolt pulls the fixture further down on the crank? It seems like it doesn't have any more room to move as it is bottoming out on the oil pump...best I can tell. I will get a stock bolt and just see what it does when I tighten it down. Guess I could use a space in there too, but I don't want to mess anything up.
