LS1 twin turbo setup questions
Old Mar 27, 2010 | 03:14 PM
1967BuickGS400's Avatar
Default LS1 twin turbo setup questions
I am new to the forced induction so I thought I would ask you guys for some advice. I am going to be installing a LS1 350 with twin turbos into my 67 buick gs400. Right now I would like to keep the 350 stock and run the turbo setup. How much boost I can put to a stock ls1? After I get more money I would like to push about 16 psi of boost. What kinda work would I have to do to the 350 to safely run 16 psi?
Old Mar 27, 2010 | 03:27 PM
chevybowtie's Avatar
Any more pics of your GS. I knew a guy that had the same year.
Old Mar 27, 2010 | 03:28 PM
jomomma's Avatar
a stock ls1 cant handle 16psi! you will have to have to bottom end forged to do that. an ls1 is 346ci btw.
Old Mar 27, 2010 | 04:06 PM
elias_799's Avatar
8-10 pounds can be done reliably with a good tune.
you can lower the compression of the engine by switching to 317 heads and you can push the stock motor a little further.
meth injection is also a very good idea
Old Mar 27, 2010 | 08:08 PM
Here is a couple pics of the car.
Attached Thumbnails LS1 twin turbo setup questions-100_0128.jpg   LS1 twin turbo setup questions-josh-001.jpg   LS1 twin turbo setup questions-josh-003.jpg
Old Mar 27, 2010 | 10:38 PM
Nice Chevelle.... JK. I bet you get that alot. Thanks for the pics of your Skylark. Those hood scopes actually look good.
Old Apr 4, 2010 | 11:57 AM
alittle1's Avatar
Have you done much reading on turbos? Google it up and check out some of the information available, then decide if that is thew route you want to go. good luck
