631rwhp/700rwtq QMP Project Formula
Awesome job Rob. Are you going after my stock shortblock record?
Do you guys still plan on going to the forged setup or are you gonna run the stocker until it gives?
We finished the new engine today actually. It's a 9:1 348ci alum block w/ARP main studs. Factory LS1 heads (not LS6 or 6.0) ported by TEA and o-ringed. ARP stock dia head studs, Stock gaskets (the same as we used on the Z last), Diamond forged pistons (fully thermal coated), Total Seal rings, Eagle Rods, custom QMP Turbo-Spec hydraulic roller cam, and stock crank. Our goal is 750-800rwhp with the same T76 turbo. Pics of the engine pieces as assembled will be on the Project Formula page later this evening.
I don't understand why anybody would claim that wasn't causing the drop off?
Drive that thing down to Florida and let it rip!!
Quote:
even gave a heavily modified Twin Turbo Supra a nice view of its' tail lights
You want to elaborate a little more on that?
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
How are the injectors holding up?? Seems like you have a really safe A/F ratio with the car. Who makes the 57lb injectors?? I'm assuming that you are still using the 98PCM. Sorry for all the questions. I'm going to be doing a single turbo in my future. I have a 98 PCM. I really want to stay away from putting FAST on my car. I have the same power goals that your car is making.
And yes, still using the stock PCM with LS1Edit for now.
Rob, how do you route things pcv wise to prevent pressurizing the crankcase at those boost levels???
Hope that helps.
WOW, those springs sure made a difference. I'm running stock springs and are having the same symptoms as you. At 5400 rpm I'm 575/560. By the time I've moved to 5800, it's a dismal 429/392. I need springs
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
