Still having issues after Procharger install
I have some extra o2s lying around if you wanna try it out.
I'll have to go back down and look again. Give me a few minutes...
if they are way different than that would indicate a problem but other than that, the trims should just bounce around close to zero (but don't forget this is a start up tune).
The procharged black camaro I just built had a start up tune on it and the trims were swinging from -30 to +30 and car still ran alright
https://ls1tech.com/forums/forced-in...c-build-7.html
What exactly did you change on the car since the last time it ran? Steve knows his stuff when it comes to procharger cars......he has a LOT of time in mine as well as MANY others.....so if he says it's not in the tune, then you can believe it.......I will do my best to help figure out whats wrong
Did you buy new 60lb injectors? are you sure they are the brand you believe them to be?
I bought new injectors off a forum member who regularly sells them in the classifieds. I was told they were Siemens Deka 60lb injectors. Let me check to see if there's a number on them I can cross-reference to be sure. And let me just tell you...if they aren't Siemens Deka 60lb injectors, I'm going to be super-f'n-pissed off.
I will pull the O2 sensors and the extensions and examine them, and clean the connectors and see what happens. I surely hate to throw money at this problem and just buy 2 new O2 sensors for nothing.
Kyle...Clean out your inbox man. Sorry on forward.
