qmp gurus plase help
Old Jan 4, 2004 | 11:55 AM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
Default qmp gurus plase help
well due to lack of instructions can anyone tell me or show me how the alt relocation bracket goes and how the suplied power steering lines go,also if i just took my cruise control out totally will that screw anything up,and i do have cruise control,oh yeah and do i take that pupm on the drivers side out completly where the i/c tube goes.thanx guys
Old Jan 4, 2004 | 01:27 PM
Warbird's Avatar
I can answer to the cruise control right now. Mine was pulled out of it's slot and now just simply hangs loose. There is no other place to put it. I guess the prototype car didn't have cruise.
I'll have to take a look at the car for the other two.
Paul
Old Jan 4, 2004 | 05:39 PM
MIGHTYMOUSE's Avatar
my cruise box is tie wrapped with two huge ones directly above the air filter under that metal bracket under the fuse boxs
the power steering lines go out toward the radiator, away from the turbo, and back under to the rack.
if you are talking about the air pump, it gets removed completely and cap the manifold with the possibly supplied blockoff plates as well as the egr.
Old Jan 4, 2004 | 05:43 PM
i couldnt get the alt bracket on either. rob took some extra photos for me, i dont see them on the site anymore..
Old Jan 4, 2004 | 08:54 PM
ok,i got the bracket on and i still cant figure out these dam lines and the frigen belt what way its routed.but thanks for the help guys i appreciate it
Old Jan 4, 2004 | 08:57 PM
oh yeah and can i just take off the cruise control completly or will it mess somthing up
Warbird's Avatar
Route the belt as you would with the alternator on the other side. Remeber to put the tensioner back on.
Old Jan 4, 2004 | 08:59 PM
ok thanx
Old Jan 6, 2004 | 09:59 AM
jboss99ta's Avatar
If you give me a call I will tell you how you can put the cruise control on. (without the use of zip ties) I will also try to get some pics of how we have it on Robs car. If you want to just take it off the car it will not hurt anything, but I can tell you how to put it on. 812-256-6400 I'll be in until 6:00pm.
Old Jan 6, 2004 | 11:14 AM
those zip ties have done their job better than anything else i put on that week.
Old Jan 6, 2004 | 11:33 AM
jboss99ta's Avatar
MM, that might be because even you can use a zip tie.... I'm not going to get into this with you.
Now, I'm trying to help Transdamit (not fighting with you) I sent the pics of how we have Robs cruise control on tell me if you do not get them.
I'm just sorry that you (Transdamit) has to put up with MM, and others getting in the way.
Old Jan 6, 2004 | 11:44 AM
kp's Avatar
kp
You can just remove the cruise module/cable if you wish, there will be no lights and nothing will be affected. Except the cruise wont work of course.
Old Jan 6, 2004 | 12:25 PM
i'm not asking you to get into anything with anyone. am i not allowed to respond to a flame against me with my opinion now?
transdamit's car would not be running so soon without my help.. feel free to not take my word for it.
Old Jan 6, 2004 | 01:34 PM
Rob Raymer's Avatar
Old Jan 6, 2004 | 02:09 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Let's stop poking each other otherwise I will be handing out "I got banned by PSJ" stickers pretty soon.
Transamdamit all squared away, or do you still need install help?
Might be some good points in here regarding gaps in the instructions if the install of say the alternator brackets is not intuitive from the design of the piece.
Old Jan 6, 2004 | 02:13 PM
jboss99ta's Avatar
PSJ, my first post was not pointed at MM, I just said I can tell him how do it without zip ties. MM took it the wrong way, or used it as a chance to try to say something.
Old Jan 6, 2004 | 10:40 PM
thanx john,i didnt get the pic but its ok because i just took it out completly,i dont care i wont ever use it anyway,also i just had to put the screen back in the mass air sensor because of some tuning issues ,primarilly idle and part throttle,but i will do a full write up when i get the #s on fri,thats if you all want a write up if not tell me so i dont have to type cause i cant very good.
