View Poll Results: How much power can LS6 Heads handle?
500-599 rwhp
2
5.13%
600-699 rwhp
7
17.95%
700-799 rwhp
8
20.51%
800-899 rwhp
16
41.03%
900-999 rwhp
3
7.69%
invincible
3
7.69%
Voters: 39. You may not vote on this poll
What's the power limit for LS6 Heads?
Old Apr 1, 2010 | 08:21 PM
white01ss's Avatar
Default What's the power limit for LS6 Heads?
LS6 Heads: How much power can they take before they start lifting?
The purpose of this poll is to find out where LS6 heads start having problems keeping a tight seal on the combustion chamber. As mentioned below, this applies to both 243 and 317 casting heads. Bonus points to voters that have lifted a head.
If you vote, please answer:
lifted a head?
what casting?
using head studs?
max power level?
injecting h20/meth/alky?
how much boost?
static compression ratio?
Old Apr 1, 2010 | 11:11 PM
blue00ZZleeper's Avatar
I to am very interested in this seeing as how I should get my PRC Stg 3 LS6 heads tomorrow for my 370-D1 build. I've seen quite a few cars on here make between 700-800 on them. They have a pretty thick deck which is good from a stock casting head and ovbiously good for boost. The LS6 and 317 heads iirc are some of the best besides aftermarket high dollar heads like AFR's or TEA's.
Old Apr 2, 2010 | 10:40 AM
white01ss's Avatar
Default for the love of... vote
I did an exhaustive search yesterday but couldn't find much about LS6 GM heads. I even checked a few of the other LSx forums. Found lot's of discussions of the limits of this or that block, but not much about heads. This all started because somebody in the industry told me that LS6 heads start lifting around 700 rwhp or 15 lbs of boost. Funny, after I posted this poll it became the first result on Google searching for: "ls6 head lifted boost".
Old Apr 2, 2010 | 10:51 AM
LS1RedZ's Avatar
Im currently running 15psi and made 754rwhp with my TEA LS6 heads. Im using head studs as well. Compression is around 9.1:1 and im using straight pump gas. Havent had any issues yet. I dont think I should either. Give TEA a call.
Old Apr 2, 2010 | 11:03 AM
dschmittie1's Avatar
4DRUSH not sure if he is on here but is on corvette forum has gone 8.90 with stock LS6 intake and LS6 heads with a YSi
Old Apr 2, 2010 | 04:32 PM
white01ss's Avatar
Thanks. Beginning to think the "weak" GM head myth was spread just to sell aftermarket heads. "Don't go over XXX or that GM stuff will break!"
Old Apr 2, 2010 | 06:56 PM
Novistar's Avatar
The blower is paxton novi 2000, but you are correct about the heads!
Old Apr 2, 2010 | 07:27 PM
fatmat80's Avatar
in a week or two i will be installing my prc stage 2.5 headed forged 347 with a d1sc and running 12# of boost thru it..from all the people and shops i have talked to they say you should be fine as long as you use arp head studs, good gaskets and your surfaces are square...but we shal see..
There are a few people in my area that are running low 600 rwhp and have had no issue to this point..
Old Apr 3, 2010 | 03:16 AM
Well I just got my stage 3 LS6 heads tonight. They look pretty awesome. 311 int 233 exh. I should be feeding them 16ish psi hopefully.
Old Apr 4, 2010 | 12:05 PM
fatmat80's Avatar
^^who ported them?
Old Apr 4, 2010 | 01:58 PM
Patriot performance. They look badass!
Old Apr 5, 2010 | 03:54 PM
stevieturbo's Avatar
These LS1 heads seem to be doing well.
http://forums.corvetteforum.com/c5-f...ls1-heads.html
Old Apr 6, 2010 | 10:05 AM
white01ss's Avatar
Nice find. Mid 9's with 16-17 psi of boost and stock 03 vette heads, not too shabby. It's rare to find a racer in the 9's with stock GM heads. I guess most upgrade for more power before there's a problem.
Still no report of a lifted head, though. Bob, you out there?
Old Apr 6, 2010 | 10:10 AM
well I am hoping my home ported 243 casting heads go in the 9's Maybe it will go in the 9's first time out tomorrow night.
Old Apr 6, 2010 | 02:13 PM
LS1x2's Avatar
Formerly 4mulaJoe
I wouldn't be afraid to push unmilled ls6's to 900rwhp. I'm making 713rwhp on mine with stock gaskets/bolts. They have never been off. Detonation is the cause of heads lifting on these motors more often than not.
Old Apr 8, 2010 | 02:00 PM
white01ss's Avatar
Can't find a reason not to think they could handle 900. People running 8's and 9's with these heads.
Old Apr 8, 2010 | 03:50 PM
Photochop's Avatar
You also need to remember that the LS6 head and 317 head are VERY similar and theres guys known for pushing 800-900 out of those as well.
Old Apr 9, 2010 | 11:29 AM
white01ss's Avatar
Thanks for that. Added note in first message. Looks like 800-899 range is gaining ground. Keep the votes coming...
Old Apr 9, 2010 | 12:03 PM
fatmat80's Avatar
glad to see thses results makes me feel reel good about my decision to go with my stage 2.5 ls6s
Old Apr 14, 2010 | 05:50 PM
white01ss's Avatar
Saw a few other cars with 800+ rwhp. They should come vote!
