Glide or TH400?
Old Apr 5, 2010 | 05:43 PM
MelScrilla's Avatar
I'd go with the th400 especially with that 3.00 gear. With a glide it would probably be a dog of the line.
Old Apr 5, 2010 | 08:26 PM
reamo04's Avatar
Next question for ya guys. Guy I know has a TCI th400 RMVB, T-brake, and comes with a 3600 stall. It was behind his 540. I know there was nothing wrong with it when he took it out, but its been sitting for 18 months. Think it would need a rebuild or just try putting fresh fluid in it and a new filter and see if it works?
Old Apr 5, 2010 | 08:29 PM
1BAD_LS1 Tunes's Avatar
If it were me i would put it in, change filter and fuild, let it idle for a while, run through the gears a few times, then drain the fuild and change filter and fuild again.
Old Apr 5, 2010 | 08:32 PM
reamo04's Avatar
thats what I was thinking. I had a car sit for about that long with the trans still in the car. Changed fluid and filter, let it idle, changed it again and it was fine so I imagine this probably will be too. Its dirt cheap too (400 picked up)
Guess we know what im going with
Old Apr 10, 2010 | 04:37 PM
reamo04's Avatar
well, getting a built th400 with a stall that was done for a blown 355 SBC for 400 bucks. :-)
Old Apr 10, 2010 | 06:02 PM
ninetres's Avatar
You know what they say: When it sounds too good to be true..........
Old Apr 10, 2010 | 06:33 PM
reamo04's Avatar
I know the guy selling it though
He had 3 cars
a 41 willis coupe with a 572 BBC with an exact copy of this trans behind it
a 23? tbucket with the 355 and blower with this trans behind it (i rode in it two weeks ago to verify the trans was still good)
and a chevelle with a 502 with a blower in it and another exact copy of this trans.
He sold the willis and the chevelle, and sold the tbucket and the guy didnt want the trans. He is moving across country so he wanted a quick sale. So.....I am snatching it up
But, I did verify the trans was still good haha. This one is a stock style valve body though which kinda sucks. O well, a RMVB is only 200ish
and I know the owner of the shop that did all the work on the trannys and the cars, so that eases my mind as well.
Old Apr 11, 2010 | 10:42 PM
SIC LSX's Avatar
glide,glide,glide
Old Apr 11, 2010 | 11:09 PM
reamo04's Avatar
Originally Posted by SIC LSX
glide,glide,glide
believe me, I know glides and turbos go together like tunafish and lamb....or....peanut butter and jelly for you guys, however ive tried finding some local. People still want 300 for just a core
That and with my 3.00 gears, I was worried about launching without tremendous HP like you are running
Old Apr 11, 2010 | 11:46 PM
SIC LSX's Avatar
turbos love the load of the glide! Ive seen many people go fast with the glide over a th350 and th400! Na and turbo with same gears as b4. Im going to run 308's with a glide and still DD mine when i go turbo
Old Apr 11, 2010 | 11:59 PM
ninetres's Avatar
I would definitly NOT pick my trans based on a currect gear ratio lol. Its a few hundred bucks to do a gear swap......and several thousand to swap transmissions. If the trans and converter turn out to work great......then you cant argue with your decision. But a gear swap and a glide is what I would have done.
Old Apr 12, 2010 | 07:11 AM
  #32
Josh@PremierAutosports's Avatar
Glide hands down. Every car we have put a glide in has went faster, every car. The most eye opening was a 02 SS that weighted 3920. It has a mild 427 and a 150 shot. First pass went 9.8x, he switched to a th400 has after 30 passes has not been back in the 9's yet. The converter with the glide was my Neal Chance setup for turbo and the th400 is a Precison speced for the setup.
Old Apr 12, 2010 | 02:12 PM
  #33
reamo04's Avatar
at what point do you need to change from the stock bellhousing on a glide?
Old Apr 12, 2010 | 05:32 PM
  #34
ninetres's Avatar
Never if you run the CSR SFI sheild.
Old Apr 14, 2010 | 09:19 PM
  #35
chrismcdaniel's Avatar
i got a brand new rossler T2 TH400 with JW ultra bell, Trans brake, Deep pan, TCI flex plate, ARP convertor and flex plate bolts , Flexable dip stick intalled and calibrated from rossler, cross member, all an fittings, cooler, braided lines with AN fittings,B&M carbon fiber shifter im selling as a package deal... all bran new. pm me if intersted
Old Apr 19, 2010 | 11:53 AM
  #36
reamo04's Avatar
well guys, by time I got to town to go get the trans, he had it sold already.
So.......I picked up a glide yesterday morning :-D
Old Apr 19, 2010 | 07:21 PM
  #37
Good choice
Old Apr 19, 2010 | 07:51 PM
  #38
reamo04's Avatar
Originally Posted by Josh@PremierAutosports
Good choice
yeah I didnt realize how cheap a rebuild on a powerglide was either!
The glide I bought from my friend has
TCI pan, hardened input shaft (still glide style, so that'll get switched to th350 shaft more than likely), and a b&m rebuild kit in it, tci transbrake. Clutches are fried (6k RPM trans brake launches in a nitroused chevelle), so those will be replaced with red clutches and we'll see how she holds up for now!
I paid 140 bucks for it knowing what was wrong with it, and he gave me clutches to put in as well.
