Thread Size of Elbow above the oil filter.
Old 04-06-2010, 06:33 PM
czwalga00gt's Avatar
Default Thread Size of Elbow above the oil filter.
Right now there is a plug in it. I'm going to tap it for my oil feed line.
Here's a pic of the elbow.
Old 04-06-2010, 06:56 PM
black98ws6ta's Avatar
In an f-body that same adapter is on the rear and a 1/8 npt taps it nicely. There are also some for the vette that are more like 1/4 npt.
Old 04-06-2010, 06:57 PM
SilverCC's Avatar
Well they are usually 1/8 NPT elbow to #3 oil line, but a 76mm might require a larger oil feed line not sure check manufacturer.
Old 04-06-2010, 07:18 PM
They sell 1/8 to -4 an. That's what i'm using on the turbo end, the inlet is 1/8.
Old 04-06-2010, 08:46 PM
JAX04's Avatar
1/8 by -4 here
Old 04-06-2010, 09:28 PM
reamo04's Avatar
i drilled and tapped it for 1/8 NPT. running 1/8 by -4
Old 04-07-2010, 12:07 AM
bgblockelcamino's Avatar
i drilled and tapped mine. if not i have spacer blocks here from turbo technolgies that sandwichs in there and is drilled and tapped already
Quick Reply: Thread Size of Elbow above the oil filter.
