let's see those procharger dyno sheets!
Old 06-23-2010, 09:51 AM
AFASTYZFR1's Avatar
Originally Posted by lordrazo
what is everyone running for compression ratios!! and head gaskets thanks
Mine is around 10.3 and I run stock 3 layer mls head gaskets with arp head studs
Old 06-23-2010, 04:02 PM
Aster's Avatar
Originally Posted by DanWS6
Bogus downshift spikes for the win.
Wow Dan, that graph looks like my daughter might have drawn it.
Old 06-23-2010, 05:16 PM
DanWS6's Avatar
Last time I locked the converter on the dyno I had to have the 3-4 bands replaced. I've been wary of doing that ever since.
Old 06-23-2010, 07:05 PM
WAHUSKER's Avatar
My initial dyno #s are in my sig. Max power at 14 psi at 6k rpms & 20* timing, max boost was 16psi at 7k but the hp was down ~100. Now that I've installed Pat Gold Ext springs & a 4" cutout I want to go try it again. The car is out of the paint shop now so SOON!
specs - 408, 9.2:1 cr, F1-C, Callies Dragon Slayer crank, Mahle -8cc coated pistons, Callies H beam rods, EPP Stage 3 cam, Morrel lifters, stage 3 317 heads w 2.05 int & 1.6 exh, .051 Cometics, ported Vic Jr, Edlebrock rails, 85 lb injs, ported 78 mm TB, EPP FMIC, Nasty Stage 3 fuel system, Alky Control meth, SDCE bracket, 8 rib ATI 7.25 crank & 3.7 blower pullies, 4L60 with the works, Yank PYE3400, Moser M9, Speed Secrets 2 Bar SD tune
Even with my 335 Hoosier DRs on I had to roll into the throttle (NO traction). And removing my air cleaner picked up 35hp, I want to try removing my custom air hat next time.
Old 07-01-2010, 09:46 PM
SnIpEz's Avatar
Originally Posted by Bob@BruteSpeed
LS2/402 with our cam, AFR 225 heads, FAST 92mm intake, ProCharger F-1A at 12.5 psi, and Kooks 1-7/8 headers. Bob
Wow. Can I get a little more info on that one plz?
Also what's the difference between an F-1A and an F-1C really?
Old 07-05-2010, 10:01 AM
vmapper's Avatar
that looks like a fellow cadillac cts-v member, Bob Johnson.
Bob now BruteSpeed, knows his procharger stuff!
http://www.exoticperformanceplus.com...Car.php?car=29
the F-1A / C have different volute diameters and CFM ratings, larger Inlet diameter and a larger inducer... i would conclude the impellers are different as well.
Quick Reply: let's see those procharger dyno sheets!
