Anyone using a turned crank?
Old Apr 12, 2010 | 11:13 PM
candlelit's Avatar
Default Anyone using a turned crank?
Well I ended up with the wrong crank and now I have to find another, that I can afford, for my engine build. It will be a 9.2CR 365ci Iron Block. I'm wanting to know if any of you are using one, how much is it turned, any problems, and what power/boost levels are you guys at? Thanks
Old Apr 12, 2010 | 11:43 PM
ninetres's Avatar
The one I am running is turned 10/10. No biggie. Info in my sig. Probably at or near 1000whp.
Old Apr 12, 2010 | 11:54 PM
Whistler's Avatar
Sawzall and Welder Mod
I don't think it has any effect other than needing thicker bearings.
Old Apr 13, 2010 | 05:26 PM
candlelit's Avatar
k. keep in mind this is cast iron, not forged 4340. anyone else before I purchase one that's turned? thanks everyone
Old Apr 13, 2010 | 06:04 PM
BadgeZ28's Avatar
Most used cranks are turned 10/10 to clean and true up journals. The loss of strength is very small. I have seen 900 HP mentioned as a limit for stock nodular iron LS cranks. There are methods to harden the surface of the journals after the grind. I think one is called pachardizing?
Old Apr 14, 2010 | 03:43 PM
gnx7's Avatar
.010 is something like the thickness of a piece of paper or a hair. I wouldn't trip on it.
Old Apr 15, 2010 | 11:16 PM
candlelit's Avatar
thanks guys.
my new problem is the crank I'm buying the guy doesn't know how much it was turned. will the machine shop be able to tell so I can order the right sized bearings?
Old Apr 16, 2010 | 12:03 AM
ninetres's Avatar
Originally Posted by candlelit
thanks guys.
I wouldnt buy it before I knew how much was cut off. And yes, a machine shop can see how much has been removed.
Old Apr 16, 2010 | 12:10 AM
black98ws6ta's Avatar
I'd just buy a standard one, they can be found easily.
Old Apr 16, 2010 | 05:32 PM
candlelit's Avatar
well the guy told me "it was turned about the minimum you can go, and still use factory bearings." either way, with it being turned & polished and the deal I'm getting will be worth buying it, even if the shop has to mic it. thanks everyone!
