people that moved their radiator verticle...
Old Apr 12, 2010 | 11:45 PM
C Murda's Avatar
Default people that moved their radiator verticle...
im just wondering where some of you are getting those nice aluminum radiator suppor shrouds to hold your griffin or aftermarket radiator up after cutting your radiator support???
Old Apr 13, 2010 | 07:13 PM
reamo04's Avatar
we make them ourselfs. Not too hard. Buy sheet metal, put it in sheet metal brake, bend it.
Old Apr 13, 2010 | 08:32 PM
Ping King's Avatar
Just bought a brake. Ill post pics of my bending.
Old Apr 13, 2010 | 09:57 PM
MUSTANGBRKR02's Avatar
Chris let me know the size that you need and i may be able to make you one at work.
Old Apr 13, 2010 | 10:42 PM
C Murda's Avatar
haha sounds good!... im in the process of cutting the radiator support now i may be gettin lucky tho as i cut out some of the lower support so my griffin rad can sit lower im hoping to be able to stand it up perfectly under the top thin piece of the radiator support after im done cutting out underneath it... may have to just cut an opening where the fill cap of the radiator will sit...we'll see tomorro when i go back to work on it.
ill post pics when im done with the cutting...then after i respray the engine bay too...need some hot weather tho to help with paint drying!
Old Apr 14, 2010 | 07:18 PM
C Murda's Avatar
oh ya my plan worked out NICELY! ripped apart the front end and made room for the cutoff wheel and cut out what was in my was and the radiator now sits flush under the top portion of the factory radiator support. no need for a shroud now and i can still use my upper intake box... maybe gonna modify it some seeing as it no longer holds a radiator...
Old Apr 14, 2010 | 07:44 PM
Good deal. Post some pics so we can see what you did.
Old Apr 15, 2010 | 11:37 AM
MTBSully's Avatar
bump for a local. where you from?
Old Apr 25, 2010 | 09:05 PM
C Murda's Avatar
from marlborough...waiting on painting the engine bay then ill post some pics of the finished product.
Old May 13, 2010 | 01:42 AM
505OUTLAWZWS6's Avatar
Pictures?
