APS TT not reaching set boost.....??
Old Apr 23, 2010 | 03:24 PM
  #41
tomz28's Avatar
I believe SP1 is WG springs only. Reaches ~7psi
take off the controls of the eboost all together DONT run it. just a staight line from the turbos to the WGs
than tell me what boost you get
than take off the lines and go drive it. slow adding RPM and whatch the boost(dont overboost it) try it and get back to me.
are you on a stock bottom end?
Old Apr 23, 2010 | 03:55 PM
  #42
02blackbeauty19's Avatar
Im not sure about the F-Body turbos, but these turbos with the corvette kit do NOT have fittings on the compressor housings, so Im using a boost source in the charge piping pre-TB.....With that said, its a huge pain in the *** to remove the SS braided lines I put in yesterday and re-do the routing for testing what it reaches on the WG.
The car is still on jackstands now, with the bumper coming off soon, so Ill see if that massive boost leak fixes the issue before I do anything else.
No, I have forged internals.
Old Apr 23, 2010 | 11:15 PM
  #43
tomz28's Avatar
im a jackass i miss that post. ya that is going to help alot LOL
do you have a wideband O2 in the car?
Old Apr 24, 2010 | 12:37 AM
  #44
No worries man. Your help has been great so far.
I do have a wideband, but its been acting funny as hell lately too!
Old Apr 24, 2010 | 08:36 AM
  #45
tomz28's Avatar
what kind is it
Old Apr 24, 2010 | 03:38 PM
  #46
what kind is it
Its an AEM. It hasnt worked right since I put the turbos on. I dont know if the little bit more of excess oil is messing with the sensor or what.
UPDATE: ITS FIXED !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! As I said, there was a massive leak coming out of the passenger side IC coupler. Pulled the bumper, removed all the shitty hose clamps, cleaned the couplers and piping, sprayed with hairspray so that when it dries it will be sticky as ****, and put all new T-Bolt clamps on.
I just test drove it and reached 21.1 psi as I let off without going all out. I just started turning it down until I reached what I wanted SP6 to be set at. Its a whole new car.....
Big shout out to you guys that have taken the time to help troubleshoot this issue. Its much appreciated.
Old Apr 24, 2010 | 03:44 PM
  #47
MY99TAWS6's Avatar
Excellent you figured it out.
For sure I am going to replace all my silicone couplers and get good tbolt clamps now as well.
So did it just come apart or tear?
Old Apr 24, 2010 | 03:54 PM
  #48
It seemed to just back off and wasnt all the way on the IC so the air would just blow out under a certain amount of pressure.
I was lucky to have such a great store/shop in town that carries the good T-bolt clamps, as well as anything you can possibly imagine for hoses/hydraulics/AN Fittings/etc.....
Old Apr 24, 2010 | 04:49 PM
  #49
tomz28's Avatar
sweet bro thats great. im happy it was something small.
id figured you look at all that stuff frist LOL.
well now you have sweet SS boost line
Old Apr 24, 2010 | 05:31 PM
  #50
Thanks a bunch, Tom!
I did address the charge system first and I actually tightened that clamp once. It was barely on the IC though so it must have worked its way off the tighter I got.
Now I have cleaned and lubed WGs and sweet looking SS/AN vacuum hoses. Thats just a couple less things to worry about, maintenance wise, in the future.
Old Apr 25, 2010 | 09:29 AM
  #51
tomz28's Avatar
my innercooler pipe would do the same thing, and slide off
is your wideband working ok now?
Old Apr 25, 2010 | 06:16 PM
  #52
No, Ill try to check for obvious causes sometime this week
Old Apr 25, 2010 | 06:38 PM
  #53
tomz28's Avatar
unhook the power from it and see if starts working right again. my WB would do the samething
Old Apr 25, 2010 | 11:57 PM
  #54
For real? Your talking about the standard 12v power source? lol
