ATI balancer or SLP?
Lots of info in "search" but the ATI damper is probably the most commonly used, even though it's a little pricey. That's what I'm using. Make sure to pin it to the crank, you need the ATI pin kit.
Rob (Bad30th)
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
A spring tensioner system of some type is definitely better than the standard Procharger J bracket as belts stretch as the RPM increases. Without a tensioner to take up the slack you will likely end up with slipping problems over time.
