boost/vacuum reference help please
i read the sticky and did a search. here is my first problem.
-i have a JGS 60mm Blow off valve and it has two ports. my motor make about 20" of vacuum at idle. if i hook it up to the top port then it hold it open at idle, closes when revved, and open once again when released. do i use the top port or side port?
-2nd problem i have is reference for my fuel pressure regulator. i have an Aeromotive with a 1:1 reference. does it need reference after or before the TB? i figure since my motor makes 20"+ of vacuum it would drop the fuel pressure from 58 psi to 38-40 ish. is this what will happen?
so at idle the BOV is open and pulling in unfiltered air?
i will reference my FPR after the TB tomorrow to see if i can get this thing to idle. will it pull my Fuel pressure down 20 psi when i am in 20" vacuum?
