Valve Spring Issue on D1SC 347
Old Apr 19, 2010 | 12:02 PM
ss.slp.ls1's Avatar
Originally Posted by Boo"SS"t
There's your problem, @ 130lbs you're just bleeding off your boost, not enough pressure to keep the valves closed. I had the same issues with my AFR 225's w/ standard springs which were rated at 135lbs closed seat pressure, I ended swapping the springs for their optional higher rate springs and solved all the valve float problems.
What was the spring rates of the new springs? I want to know how they compare to PRC duals or Patriot Extreme duals...
Old Apr 19, 2010 | 12:36 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by MrDavid
I believe i'm going to change my springs to PRC Gold Dual Xtreme's in about 2 weeks. I planned on running 100% methanol when I ordered the kit, but my tuner said I needed 50/50 so thats what I did. Seemed to work very well dropping intake temps 40+ degrees and he added a good bit of timing.
We've seen quite a few cars fall on their nose with 50/50 as the water puts out the flame, you're lucky that you didn't have problems with it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 19, 2010 | 01:17 PM
Boo"SS"t's Avatar
I can't remember exactly, but I think it's 155lbs @ the seat and 428lbs@ .650lift. It's not really that high of a rate compared to other springs that I've seen around here, but I did'nt want the hassle of pulling the heads off to have the seat machined for a bigger diameter springs.
Old Apr 19, 2010 | 01:26 PM
ss.slp.ls1's Avatar
The Patriot Extreme duals are rated at (per Patriots website):
Spring Pressure Closed: 155 lbs. @ 1.800"
Spring Pressure Open: 410 lbs. @ 1.140"
Coil Bind: 1.090"
Old Apr 19, 2010 | 04:06 PM
MrDavid's Avatar
Pretty sure thats not an issue on my car as the meth kicks in @ 4lbs and no issues occur until it hits 11.5-12lbs.
Old Apr 20, 2010 | 08:15 AM
LS1Tech Sponsor
You might want to try 100% meth though before you swap out valvesprings just to rule it out. Bob
__________________
Old Apr 20, 2010 | 02:54 PM
MrDavid's Avatar
I'm nearly 100% positive thats not causing the problem. If it were, the car would get extremely rich right after the meth kicks, which is probably around 3000rpms. All the symptoms point towards valve float.
I am now looking to invest in the Livernois Motorsports LS dual valve spring. Its rated at .690 lift and has 150lbs of closed seat pressure. If that doesn't solve it, i will try 100% meth just to humor you.
Old Apr 20, 2010 | 03:19 PM
Sluggish's Avatar
I have the same issue with the same springs but with a bigger cam, dyno graph even looks the same
Old May 28, 2010 | 09:50 PM
MrDavid's Avatar
To any of you who were still following this thread the problems have been resolved.
To start out, all the springs were changed to Livernois Super Duty springs (150lbs seat pressure). This didn't fix the problem though. Symptoms were still the same.
So I called Bob and we talked about it for a while and he convinced me to try a shorter belt and I also purchased a new idler pulley from him since mine was a little dinged up from the previous owner. I also went with 100% meth instead of the 50/50 mix.
Car got back on the rollers last Wednesday and put down an impressive 730hp 640tq. I was pretty happy with these results. It made 17lbs of boost.
Graph can be viewed from my tuners website here: Dyno Graph
Hopefully those of you who had an interest in this thread will remember these problems and be able to point someone else in the right direction if you see a problem like this arise again. Thanks.
Old May 28, 2010 | 11:47 PM
tomz28's Avatar
im glad to see you fix it. that always makes my day to see something fix after so much work and BS. i know your pain
congrats buddy
Old May 29, 2010 | 01:06 AM
ss.slp.ls1's Avatar
Wow, that's a lot of psi from a D1SC.
Old May 29, 2010 | 06:02 AM
  #32
LS1Tech Sponsor
Thumbs up
Thanks for the call to update me, I appreciate it! Bob
__________________
Old May 29, 2010 | 09:33 AM
  #33
MrDavid's Avatar
Yea, its a little more than I was hoping for. In the near future, i'm going to swap the LS6 intake for a LS2 and upgrade to a Nick Williams TB, change my exhaust to a setup with cutouts and also upgrade to a larger intercooler. Hopefully drop it to 14psi.
Old May 30, 2010 | 02:31 PM
  #34
Aster's Avatar
What pulley combination are you using to get you 17 psi? It doesn't sound that far out of range on a forged 347.
Old May 30, 2010 | 02:35 PM
  #35
MrDavid's Avatar
3.40" blower pulley, 7.53" ATI Super Damper
