Hot Wire Installation question
Old Apr 24, 2010 | 02:38 PM
BadgeZ28's Avatar
Default Hot Wire Installation question
I bought a fuel pump hot wire setup last fall. I just went under the car and I am not finding a matching connector to plug into. I see a multi plug connector on the bulk head just above the rear end. It is on the driver's side. Do I plug the short connector there, or up at the fuel pump connector? Thanks
Old Apr 24, 2010 | 07:21 PM
elias_799's Avatar
what hot wire kit you have ?
racetronix by any chance ?
but you will need to go more then just under the car, you have to drop the tank a little
Old Apr 24, 2010 | 07:24 PM
elias_799's Avatar
here is the diagram for the racetronix hotwire kit
Old Apr 24, 2010 | 08:31 PM
BadgeZ28's Avatar
Thanks.
The one I bought came from Full Throttle Speed and it is different at the tank end. There is a short cable with a male and female connector like shown and then a larger four pin that terminates to the longer cable that runs forward to the battery.
