Sway me - F1a
Edit: never mind, refined my search terms a bit. Looks like I can do an SDCE tensioner or pm Aster for his custom tensioner?
When I called procharger, they said I should be fine if I chose to run those, but sounded like the front mount IC would be the better choice. I need to find out more before I make a real decision on that however. If there are substantial gains to going with the FMIC, then sure, I will do it, but if not, the twins seem to be the easier route, no?
Somewhat related, and brought up in another thread here in the FI section, about overheating etc. This is an Arizona car, and I have had instances where cam only, as I am right now, my temps have gone over the 230-240 range and I have had to shut down (God damn you Sonic drive-in).
Would meth injection help at all as far as heat issues? It lowers intake temperature, sure, but does it help in any capacity at all for lowering operating temperature of the engine and supercharger? Noob question, I know, but I will only learn if I ask.
