How much boost before I should worry?
2 questions...How much boost can I run on this motor before I have to worry about lifting a head, or switching to 6 bolt per cylinder (which would necessitate a new block)?
What reasonable priced head ($2-2.5K) would be best to use in this situation to allow the most boost (dare I say safely)?
I plan on doing head studs FWIW...
Also, which head gasket will work best in this senario. I don't have to make a certain number per se, so I'm willing to cut the boost, where my risk starts going up significantly.
