problems with start up
Old Apr 30, 2010 | 03:46 PM
jjnitrox's Avatar
Default problems with start up
Hi Guys:
I just finish installing the P1SC-1 supercharger on a 2000 vette with the cam kit from epp.The vette has an LS2 engine. The reluctor wheel is 24 teeth same as the LS1 engine. I am using a Ls2 timing chain and sprockets. All of the wiring adapter were checked. I am having problems when starting up. it takes 5 or 6 times to start up and it misfires. I ran a check with a scanner and it reads low voltage cam sensor.Once the engine is on there are no more problems. What can I do fix this?
Old Apr 30, 2010 | 06:04 PM
ss.slp.ls1's Avatar
Is it possible that you have a 4x reluctor cam sprocket and not the 2x reluctor cam sprocket you need?
Right cam gear:
Wrong cam gear:
Since you have a specific code, you may want to check all of the wiring to and from the cam sensor for damage.
Old Apr 30, 2010 | 07:47 PM
WS6HUMMER's Avatar
What map sensor do you have & are you running an adapter harness?
Old Apr 30, 2010 | 11:21 PM
jjnitrox's Avatar
Default problem
Thanks for your response. Problem fixed bad wirring from cam sensor of racetronix harness adapter
