what radiator are you guys running?
I'll be pickin up a brand new stock 1997 LT1 radiator from O'Riellys. Just checked & they are only $110 out the door with lifetime warranty. Not sure what fan set-up yet, I"m waiting on ChevyChad to get some miles on his set-up first & if it lasts the summer without a fan failure I'll probably run what he is running.
Does anyone see any issue with running this griffen radiator compared to the griffen that is always recommended?
http://www.summitracing.com/parts/GRI-1-25221-X/
This is the one always recommended...
http://www.summitracing.com/parts/GRI-1-25241-X/
Looks like the one i have access to is 1.5" narrower and .5" taller. Does anyone see a problem with this?
#32
No it will be fine if you are still wanting to do a stand up situation. My a/c condensor is about a half inch taller than my radiator and I'm not running into any problems. I think you will cool better with the other radiator though as there is more surface area.
Stephen
Stephen
