MAF or speed density
Old May 2, 2010 | 01:37 PM
1971ls1's Avatar
Default MAF or speed density
im doing a turbo ls1 and wondering what is better, a speed density setup or mass airflow sensor i know this is problably a common question but i havent been able to find an answer
Old May 2, 2010 | 02:43 PM
ColtGT4g63's Avatar
Depends who you ask. I personally would rather use speed density.
Old May 2, 2010 | 03:10 PM
yoshgixxer's Avatar
id love a answere to this question too..the guy i bought my turbo kit from was running speed density...the reasoning for him was cuz the guy who did his tuning recomended it...well i need more of a reason then that!
Old May 2, 2010 | 05:09 PM
Jontall's Avatar
Speed density is the best and I have no problems at all.
Old May 2, 2010 | 05:38 PM
BLNLS1/RX7's Avatar
+1 for speed density.
Old May 2, 2010 | 05:47 PM
crf538's Avatar
+1 for sd. even even if they are equivalent its just less BS to deal with.
Old May 2, 2010 | 06:46 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
what about weather changes?? will SD be ok?
it might be 100* during the day and 40* at night here certain times of the year?
Old May 2, 2010 | 06:56 PM
armintheman's Avatar
ya true that's what my tuner said. he said i should run sd if it's a track car but for street driving its not as efficiant
Old May 2, 2010 | 07:17 PM
thread jacking KINDA...lol
i will be running a 408ci and a gt-91 turbo and plan on about 15psi what would be the best for me... whats the pro's and con's of both
THIS WILL BE A STREET TRUCK!!!
Old May 2, 2010 | 08:54 PM
RICE ETR's Avatar
Turbo Addict
I am still running a maf...gives me a good tune when I am just cruising around and I use it for a meth controller when in boost.
Old May 2, 2010 | 09:25 PM
AFASTYZFR1's Avatar
Speed Density! Makes response better and is just the right way to tune forced induction (PCM can "see" boost).
Old May 2, 2010 | 10:23 PM
yoshgixxer's Avatar
maybe its a stupid question but what all is need to convert a LS1 car to SD?
Old May 2, 2010 | 10:38 PM
jomomma's Avatar
It will have to be tuned for it. And for forced induction you will need a different map sensor.
Old May 2, 2010 | 10:48 PM
lordrazo's Avatar
Speed Density! and the higher the boost and power goals you might want to look into a stand alone ecu like fast and that will be speed density as well
Old May 2, 2010 | 11:46 PM
conan's Avatar
+1
I've never found a detailed explanation on this. Some say its bad and others say not so much.
I have a SD tune and I live park city UT most of my driving is at 6,500- 7,200 ft/elevation, the temp can be 40 in the morning and 90 by after noon. I have never felt any differance in the way my car drives. I also see very little, if any change in my wide band gauge. So I've been happy since the MAF to SD tune.
Old May 2, 2010 | 11:51 PM
elias_799's Avatar
what i have been told is that our computer does not read the maf past 500whp, so i after the 500whp it is a guessing game .
with speed density it is not, but does speed density correct for weather change ? i think you still keep the IAT sensor for SD, don't you ?
Old May 3, 2010 | 05:26 AM
Jontall's Avatar
Originally Posted by conan
+1
The temperature has little effect/ no effect on the speed density tune, but altitude changes would cause big problems.
Old May 3, 2010 | 06:37 AM
SS101's Avatar
just for reference (temps in Fahrenheit, density in (lbm/ft^3))
Air Density at Sea Level
20 = 0.0832
100 = 0.0705
@ 7000 feet elevation
20 = 0.0635
100 = 0.0544
onefastmx5's Avatar
You don't delete the IAT sensor, just the MAF.
The only way an altitude change would affect the tune is if the barometric reading wasn't updated with enough of an altitude change.
Old May 3, 2010 | 07:51 AM
AFASTYZFR1's Avatar
Remove MAF and replace stock map sensor with 2 or 3 bar map sensor (and of course car has to be re-tuned).
Temperature changes do not affect speed density....my AFR is the same in the winter as it is in the summer
