What would you do with this housing?
Old May 5, 2010 | 07:27 PM
98Camarod's Avatar
Default What would you do with this housing?
Old May 5, 2010 | 07:37 PM
99LS6SS's Avatar
If you're wanting to use it, have it cleaned up. Have it sand blasted and coated. Thats what I would do.
Old May 5, 2010 | 08:07 PM
Boosted One's Avatar
I would replace it. Your going to have a heck of a time getting the vband flange to seal.
Old May 5, 2010 | 08:16 PM
98Camarod's Avatar
it goes into the tiny volute also. If you've seen the housing inside, you know what I'm talking about. I can't get a good picture of that.
Any ideas what would cause it?
Old May 5, 2010 | 08:34 PM
elias_799's Avatar
if you do decide to use it, i would defiantly clean it up inside. you do not want any of that stuff getting on to the exhaust wheel
Old May 5, 2010 | 08:55 PM
98Camarod's Avatar
That's what I'm trying to figure out how to do it. I'm hoping someone will chime in that has had this already happen to them
Old May 5, 2010 | 09:00 PM
TTI George's Avatar
I've seen worse, clean it up and run it.
Old May 5, 2010 | 10:57 PM
elias_799's Avatar
sand blast it
Old May 5, 2010 | 11:52 PM
sschoeffler's Avatar
I'd blast it with some fine sand then have it hot tanked and coated, Should be good as new then.
Old May 6, 2010 | 12:19 AM
Skillet's Avatar
sand blast it
Add one more for sand blast. You will be very surprised how well it will look after a few minutes of blasting.
Old May 6, 2010 | 08:35 AM
98SuperchargedLs1's Avatar
throw it away.. i wouldnt even try and clean it. its not worth taking the chance, just find a used one around or buy a new one they are not that much money
Old May 6, 2010 | 08:54 AM
boosted LT1's Avatar
When you look at the expense of 'fixing it', add in your time, and add in worrying about it what will you save?
Is it worth the gamble? The cost of a used turbine housing isn't high enough for me to take the risk!
Good luck
Old May 6, 2010 | 09:01 AM
jay_rich's Avatar
Looks like a decent amount of moisture is passing through it, head gaskets all check good?
If you have it sand blasted I would deffinitly bring it to a machine shop and have them mill the vband flat (just enough to clean it though, you dont wanna undersize it to much)
Jay
Old May 6, 2010 | 10:22 AM
99LS6SS's Avatar
i wouldnt see any problem with sand blasting that. i used to work for a local powder/ceramic coating business and we sandblasted and coated stuff like that all the time.
Old May 6, 2010 | 10:49 AM
BlwnLs1GTO's Avatar
Is this from a Chinese turbo?
If so, make sure you can find a replacement before throwing it away. Not all turbine housings are the same and may put your downpipe flange location in a different spot, possibly making it impossible to mount everything up correctly.
Old May 6, 2010 | 12:17 PM
DrTurbo's Avatar
LS1TECH Sponsor
Simply have it blasted. We see many housings come through our door like that or much worse.
Old May 6, 2010 | 12:18 PM
qqwqeqwrqwqtq's Avatar
Agreed. We just had the downpipe flange completely rust off of an STS TBSS. Now that is rusty!
Old May 6, 2010 | 01:25 PM
1971ls1's Avatar
i say blast it and take it to the machine shop and have the v-band milled flat
Old May 6, 2010 | 04:32 PM
98Camarod's Avatar
I'll check and see how much it is to get it blasted vs buying a used/new housing
thanks for the replies
