Yes another "Help me get to 1000+ hp"
Old May 9, 2010 | 12:18 PM
InsaneDomestics's Avatar
Originally Posted by lemons12
Would this not be much cheaper/reliable with a turbo?
Probably but I don't want a Turbo. I stated that in my first post.
Old May 9, 2010 | 01:33 PM
lemons12's Avatar
How come? I am just curious..
Old May 9, 2010 | 07:53 PM
I just want something a little different. I see too many people around running Turbos. I just want to go with somewhat of an "Old School" theme and Supercharge it... Plus, I like the sound of a Procharger better
Old May 14, 2010 | 01:41 PM
John98LS1's Avatar
im doing the same thing...hooking a f1r to a built 5.3 punched out to 385 cubes.
Old May 15, 2010 | 05:55 AM
FrankSS's Avatar
thats why im doing mine too insane... i want to be different from the crowd. i already have a F1a and complete setup. as soon as i get back from iraq i will be looking into all the other stuff. i was leaning toward going with a 370 and the run as much boost as pump gas would allow, and then have a small fuel cell of race gas i can switch over to at anytime. was looking into getting that pcm setup that has the dual flash memory in it, that way i can switch pretty much on the fly, along with wiring the fuel system to switch with the different tune
Old May 15, 2010 | 01:23 PM
Ws6kid.'s Avatar
frost can do that for you...
Old May 15, 2010 | 03:04 PM
SnIpEz's Avatar
lolwut? I hope you're talking about the PCM part of his post. Any good tuner could probably do that
Old May 15, 2010 | 06:14 PM
Ws6kid.'s Avatar
talking about this...
http://www.TunedByFrost.com/products.htm
yes the pcm part...
Old May 24, 2010 | 06:08 PM
What do you guys think about using an Eagle Rotating Assembly for this kind of power? I would like to use Callies but Im not as well off as some people. I can get an Eagle Assembly for fairly cheap but Id like your opinions on its Power Limits...
Old May 24, 2010 | 09:21 PM
1fast bird's Avatar
I'm no expert on blowers. Just wondering if going with the "cheaper" rotating assembly is wise when you want a 1000hp blown car. Especially since you want it to be a reliable cruiser. An f1 or f2 takes alot of power to turn them. I would think that also puts stress on the bottom end. Maybe give Eagle a call and see if they can give any input. Again just my opinion....
Old May 24, 2010 | 09:25 PM
Yeah, I was thinking the same thing. Thats why I was asking some of these more experienced guys what they thought about it.
Old Jun 5, 2010 | 10:08 AM
  #32
19.BlknBlu.91's Avatar
Any updates on this?
Old Jun 6, 2010 | 11:37 AM
  #33
darkhorizon's Avatar
1 big turbo, and a built LSX block should work nicely.
Might be able to get away with building a LQ block as well
